Question about Friedrich QuietMaster Electronic SS12J30D Air Conditioner
Cycles off when it is still hot in room - Friedrich QuietMaster Electronic SS12J30D Air Conditioner
  • Friedrich Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 01, 2010
Dryer is extremly hot to the touch, condensation on cabinets and walls in the laundry room it gets so hot in there when dryer is running
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat. What is your model number?
Nov 28, 2010 | Electrolux Dryers
Freezer is hot on the sides is this normal?
Good day,
Yes, that is normal. It is ideal to not be in a hot room but as it reaches temperature and begins to cycle off and on it will become somewhat cooler.
Jul 20, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
TV turns off and on when hot
Check both the fan and the air entry area and make sure that both are free from dust and debris. The fan may be tuning too slowly to properly move air around. A quick vacuum of the area should help.
If that fils to correct the problem, please update this and we'll start looking at potential parts failures.
Thanks,
Dan
Jul 11, 2010 | Toshiba 65H84 65" Rear Projection HDTV
No hot water for wash cycle
Hot fill valve shot or blocked
Take supply hose off the back and check the filter is not blocked
If it is clear check that it is taking in water by running the machine with no background noise in the room.
While the machine is supposed to be filling switch the power off and listen for water dripping into tub.
No noise , no fill , new valve required
Jan 03, 2010 | Whirlpool Washing Machines
Fan Coil Unit is Cycling on and off. But the room is still hot.
Check electrical connection at the T'stat and the indoor blower . Sounds like a loose connection.
Sep 11, 2009 | Cfm Daikin R410a Split System Air...
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Room temp is not where it should be before furnace shuts down
Did the installer check the amperage at your thermostat and then adjust the heat anticipator? Or you may need to have the blower time settings changed to suite your needs. Get them back in to check.
Nov 10, 2008 | Heating & Cooling
Friedrich QuietMaster Electronic SS12J30D Air Conditioner Logo
87 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
