Question about Casio Sea-Pathfinder SPF40-1V Wrist Watch
How to turn the watch off to save power - Casio Sea-Pathfinder SPF40-1V Wrist Watch
  • 831 Answers
The only way is to pull out the battery and I dont think you want to be doing that.
Sorry.
Jewel
Posted on Sep 01, 2010
My casio protrek 2500t watch is in power saving mode but even after keeping in dark for hours between 10pm and 6 am the display does not go off.Please help.
I own the same PRW-2500-1A (all black).Check if under the hours reading, PS appears.If yes,power saving function is activated.
Normally, Power Saving Function is enabled automatically (if activated) if the watch stays in complete dark for sometime.If after a couple of hours in the dark the watch comes suddenly under bright light,the display goes on immediately.Hour interval (10pm-6am) has nothing to do with Power Saver.
Try the following:
a)Deactivate and reactivate (or vice versa) the PS.
b)Leave the watch in the dark for a couple of hours .Then,still in the dark,try,using a very low power light (just that you can,barely read) to check if display is blank.If not you may have a problem with the light sensor found at the bottom of the display.Will be a very rare case but you have to take the watch to a CASIO authorized service.
Apr 29, 2016 | Casio Watches
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Seiko 7d48 battery
    i would say when the watch stops, to save battery power pull the winder out when not in use the watch will stop.
    Jan 01, 2014 | Seiko Watches
    How to set time on GPS watch
    From your comment I have no idea what watch you have! The more infromation you provide, the likelier it is we will have a solution. However, in general, watches cannot tell if you live in a spot on the globe that uses daylight savings time. You have to enter that information. Go into your settings and see if you can turn on Daylight Savings. The watch should set the time automatically at some point, occasionally takes some time. Only a part of the world uses daylight savings, invented by Ben Franklin to save energy(coal oil) just like today!
    Nov 07, 2011 | Citizen Watches
    I opened the package and dont know how to turn it on!
    mcdevito75 Here, It must be a Quartz watch, look for a very small piece of plastic just under the stem, remove that piece of plastic, push the stem down and your watch should start. OR!! look on the back cover of your watch, carefully, if you see a plastic tab comming out of the back cover, remove by pulling carefully on that plastic tab, this plastic tab is keeping the battery from grounding, thus saveing battery power but also not letting your watch run. Simply reove this tab by carefully pulling on it.
    Jun 17, 2011 | Watches
    Dpfellside@hotmail.co.ukwhat is actually meant by daylight saving time. my Citizen watch always indicates this setting is off (I am in U.K.)
    Daylight savings time is primarily an USA thing. We set our clocks ahead every Spring in March and hour and back an hour in the fall. The idea was invented by Ben Franklin centuries ago to save energy and it is still done with the same idea in mind. Read elsewhere to see how it saves energy, debatable. Not all part of the country observe DST. Just turn it off and you should be fine. You may need to correct the time.
    Mar 23, 2011 | Citizen BL5314 52E WR200 Eco-Drive scyba...
    Screen goes blank and it says chg in small letters on the right lower side
    Actually, "chg" means "change" in this case. Since this is a solar watch, it is not necessary to change the battery. I let my watch sit in the dark for a few months and I came back to the same screen when I dug it out of a drawer. Simply allow the solar cells to get some light to recharge. I left the watch under a lamp overnight because I needed a stopwatch in the morning, and it was charged by the time I woke up. Also, this watch has a power saver function you can turn on and off. If the watch is left in the dark for about an hour, the screen will turn off but the normal functions will continue in order to save power..
    Apr 09, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
    The watch is great, but when we went to Daylight savings time earlier this year, it has not adjusted...not sure what the problem is or what to do. I've never had this problem before.
    if you alowed some to play with the watch the could have turned off the daylight saving setting off.
    casio offers this feture cuz some contries they sell watches in don't reconize daylight savings
    Jul 12, 2009 | Casio G-Shock GW700A-1V Wrist Watch
    Time keeping.
    Check in the instructions about the time zone setting and that the feature for auto day light savings are turned on.
    If you go to the manufacture site for many of these watches, they have downloadable PDF instructions. They also have service centers that can give support.
    Jerry G.
    Mar 18, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
    24 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
