Question about Whirlpool Microwave Ovens
Whirlpool Model MH7110XBB:2, Serial FGD4829185, Manuf. 1994 woked fine until it began giving the message " install probe" whenever I turn it on. The control panel is unresponsive to all attempts to actuate the Cancel or any other control panes buttons. It is totally unusable at the moment. This is Kelsall on behalf of our neighbor Norma Eldridge.
MicrowaveSvc
  • 9085 Answers
SOURCE: GE microwave error - PROBE
Chances are the keypad (membrane switch) is shorting, or the control panel as an assembly may need repair.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It shows you how to test the keypad.
Also, we repair these for $39.95 (in most cases) for customers nationwide via mail. If yours needs a keypad, we could also give you the estimated total repair cost if you contact us with your exact model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: MH1150XMT-0 (whirlpool) partially dead control panel
In order, I would suspect:
- it needs a reset
- door switch or door switch mount trouble
- your keypad is failing
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it so I can give you some advice on the other two probable causes.
Posted on Sep 06, 2008
  • 108 Answers
SOURCE: Microwave starts after plug-in cannot be stopped by control panel
This seems like a problem with with the door latch circuitry HW. If the unit is still in warranty, call GE customer care. If not, your neighbor will need to buy a new oven. Service on microwave ovens is not cost effective because the replacements are so reasonable and have so many new features.
I have a lot of experience with these units. If the door latch circuitry is in question you may be exposed to dangerous microwave energy. Hope this helps...
Ray
Posted on Nov 20, 2008
  • 6 Answers
SOURCE: Underneath the bottom panel, there are electrical
try sealing the metal up then if that does not work get a new 1
Posted on Apr 15, 2009
SOURCE: Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Posted on Jul 11, 2010
Whirlpool microwave mh7110xbb-4
Judging from what you have described, it appears the unit is now finally dead, dead, dead. Did Google search and found a bunch of them Good luck.
Aug 26, 2017 | Microwave Ovens
I hit the start button on my Whirlpool microwave oven model no. MH7110XBB-5 but got nothing but a click. Any thoughts?
The control board that is located behind the keypad is the problem, I have seen the board develop bad solder connections around the relays. If you are handy with a soldering iron you can attempt a repair, remove top "2 to 6 screws" and remove keypad with control board attached "clipped or screwed in" remember to unplug microwave before you work on it.
Jun 28, 2011 | Whirlpool Microwave Ovens
The microwave displays F-6 and won't stop unless it's unplugged. Needless to say, it can't be used.
F6
Shorted temperature probe
This code will occur if temp. probe is detected as shorted
continuously over 5 seconds.
Replace temperature probe. part no 29 Thermostat
Part Number: AP3038826 made by WHIRLPOOL
The above part and all other parts of your model can be foundin the link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260444&diagram_id=28263369#d28263369
Jan 01, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave does not heat if time is less than 1 min 30 seconds
Generally speaking, charcoal filters should be changed and grease filters should be cleaned about every six months, or whenever you notice they are getting dirty & clogged. Yours will likely have one or the other - probably not both - depending on whether it's vented or it recirculates.
A clogged filter will cause the supply of cooling air flow to be lessened, allowing the magnetron to overheat. It only takes one severe overheating to damage or destroy a magnetron.
One common way for a magnetron to fail is that its heating power is less and less, then it just stops heating.
Magnetron's will usually have a warranty of 5-9 years, but you'd still have to pay the installation labor.
You can save a $75-90 home visit by removing the oven form the wall and taking it to a local Whirlpool-authorized warranty servicer.
The date of manufacture will be on the model tag in the unit, and the warranty terms will be in the owner's manual. Many manufacturers will use the serial number and date of manufacture to validate the warranty in lieu of a sales receipt.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Jun 26, 2010 | Whirlpool WMH1162XV Microwave Oven
Mar 28, 2008 | Microwave Ovens
Microwave cooking center
Try visiting the manuf. Web Site. IF it is a major manufacturer, they normally will supply parts for their products. You didn't supply the make of your Microwave, so I am afraid I could not look into it any further for you. Good Luck!
Nov 05, 2007 | Microwave Ovens
Microwave Ovens Logo
165 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
