Washer WBSR 1060 will not drain - Washing Machines
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 10, 2008
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
I have lost the instructions for my sportline duo 1060
Hello spikey_93,
You can download the manual for your Sportline 1060 from this link:
Sportline 1060
I hope this helped you.
You can rate my answer if you find it helpful.
Sep 27, 2011 | Sportline 1060 Unisex Duo Heart Rate...
What refrigerant is use for BreeZaire wkr 1060 and
A WKR 1060 SHOULD BE AN R-22 REFRIGERANT UNIT AND IT SHOULD STATE SO ON THE UNITS TAG ON BACK OF THE UNIT.
I IT IS IN FACT AN R-22 MODEL 1060 IT USES 9oz OF R-22
IF IT IS AN R-134A IT USES 10 oz
Dec 02, 2010 | Breezaire WKCE 2200 Wine Cooler
My Bosch wfd 1060 fails to drain complety. I have to drain it via the bottom front right drainage. Any advice on what the problem could be? Thanks a mil
Check and clean the filter, make sure the outlet hose is not blocked, if all else fails and you are sure the pump is getting a power supply, then replace the pump.
Please rate my solution.
Thanks.
Nov 09, 2009 | Washing Machines
Will not spin water out the machine
THIS GE MODEL IS NOT A GOOD NUMBER WBSR IS OKAY BUT AFTER THAT THERE IS SOMETHING MISSING OR WRONG. IT SOUNDS LIKE MAY REQUIRE PUMP OR THERE IS SIMPLY SOMETHING CAUGHT IN ITS IMPELLERS. IN ORDER TO FURTHER DIAGNOSE THIS AND TO GET A PART NUMBER FOR THE PUMP I WOULD REQUIRE A MODEL.
THANKS
Oct 12, 2009 | GE WBSR3140DW Top Load Washer
My washer will not spin while in permanent press or any load cycl
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Mar 29, 2009 | GE WBSR3140DW Top Load Washer
Ge wbsr washer overflows...
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
Jun 05, 2017 | GE WBSR3140DW Top Load Washer
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Dec 20, 2008 | GE WBSR3140DW Top Load Washer
My siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
