Question about Passport 8500 Radar Detector
The button on top of the escort 8500 that attaches the suction cups to the main unit (for the purpose of sticking it on the windshield) is stuck/broken and will not successfully attach so my radar detector can no longer be attached to my windshield. Where do I send it to be repaired?
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
WIll not adhere to the windshield... suction cup does not hold GPS
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Dec 31, 2010 | Tomtom GPS
Mount no longer sticks to windshield
Well a new mount suction cup will need to be purchased. you can grab one at radioshack.com you alsmo might want to wet the plunger then try to stick it. Or clean of that dirty windshield and try again.
2 solutions
1. clean the windshield and apply a little water to the back of it.
2. Buy a new suction cup.
thats all I hope you to stop by and rate it thanks.
Apr 16, 2010 | Tomtom ONE GPS Receiver
Suction cup does not stick to the base of the tom tom..Everytime I try to attach the suction cup, it just falls over. Help
  1. If you will stick the suction cup to your windshield make sure to clean it first use dry clothe and put pressure while rubbing it to the windshield.
  2. After cleaning it before you stick the suction cup to the windshield make sure the lock is release and then put a pressure and then while pressing it then that's the time you will lock it.
Feb 06, 2010 | Tomtom ONE GPS Receiver
I got the standard mount with TomTom GO 730 and it just does not seem to work. The first time I had placed it on my windshield which I was later told was the wrong place to put it (the included maual in...
This is a fairly common issue especially with aftermarket tinted car windscreen 'film'.
You can try prolong the suction by wetting the suction cup with water of very slightly soapy water before applying it to your 'clean' windscreen area.
As for the dashboard, for some models, TomTom provide a plastic circle to which the suction cup attach to. The plastic circle is first 'permanently' attached to your dashboard with double-sided adhesive tapes.
Hope it helps: let me know how you go.
Jan 08, 2010 | Tomtom GO 730 Car GPS Receiver
GPS will not stick to the windshield.
Check to make sure that the suction cup you have is the appropiate size for your GPS unit. Also check to make sure there is no grease or other slippery substance on the windshield or suction cup that stops it from sticking to the surface. If you have something like Rain-X on your windshield, you will need to clean the area where the suction cup will be placed, and after that, it should stick.
Oct 29, 2009 | Garmin StreetPilot C330 GPS Receiver
Xl340 no written instructions on mounting
It sticks to surfaces that a suction cup mount does not stick to.
Jun 19, 2009 | Tomtom GPS
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Dec 07, 2008 | LG LN740 GPS
I have two NUVI 660's and one 360 (?) navigation systems. They all work great except all three have the same problem with the suction cup. Aftera few months, they will not stay attached to the...
Hello rkfowler,
While the suction cup mounts included with most GPS units are very effective, they certainly can fail. It sounds like you are doing everything you can to make it work: cleaning both the windshield and the cup itself. You also might try putting a few drops of water onto the suction cup before affixing it.
If the suction cup mounts aren't working out for you, Garmin does have a couple of other options including a vehicle mount that uses a super strong adhesive or a friction style mount. These are available from Garmin directly on their website (www.Garmin.com) or through your local consumer electronics store, such as Best Buy.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Garmin Nuvi 660 GPS Receiver
Passport 8500 Radar Detector Logo
361 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
