Question about Hitachi 53SBX59B 53" Rear Projection Television
Picture movement and lines - Hitachi 53SBX59B 53" Rear Projection Television
  • 51 Answers
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Google “Hitachi convergence repair” and you’ll find many sites that will educate you on how to repair and where to get the parts needed for your Hitachi PTV.
Posted on Sep 01, 2010
LED LG 55LS4500 multi color vertical lines no picture but do have sound, what causes this?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 23, 2016 | LG 55LS4500 55 in. TV
Tip
Digital cameras tip :lines and shapes
<p>We all bethink our geometry classes, bedeviled by circles, triangles, and snake-like curves. Applying these simple shapes to your accountable amount can advice to abridge circuitous scenes and add beheld interest. Consider aggravating to abduction an angel of a being walking bottomward a long, beeline street. Instead of cutting beeline bottomward the line, move yourself bristles or ten anxiety to the ancillary and shoot that alley at an bend - accepting that band bridge through the intersecting curve of the abstract tic tac toe lath from the aphorism of thirds can actualize the apparition of movement as they advance the eye through the picture. S-curves are alike added dynamic, while repetitive curve can additionally actualize movement of the eye through the picture, like repeating after-effects of bank on a bank or alongside row houses forth the ancillary of a road.
on Dec 23, 2010 | Cameras
Picture showing lines and small squares with a sticky movement
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 13, 2014 | Panasonic Televison & Video
What is diferent betwin 1920*1080p and 1920*1080I
Television pictures are a series of still pictures that are presented quickly to give the illusion of continuous movement.
1080p and 1080i indicate how these pictures are formed.
1080p is progressive scan. It is a format that "paints" the picture left to right, top to bottom. On older tube type screens, this would cause the top of the picture to be dimmer than the bottom, as the phosphers would fade before the next picture was painted.
1080i is interlaced scan. This format paints every other line from top to bottom, and then paints the lines it missed before moving to the next picture. This evens out the brightness.
If your TV is capable of 1080p, it is considered to be the best picture (but you probably won't see the difference).
Feb 04, 2011 | Audio Players & Recorders
Color blue will not adjust on crt color conergence adjustment , picture on tv is double with blue on right side, auto/manual mode , the color blue will not adjust on right or middle side from side to side,...
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | JVC AV-56WP74 56" Rear Projection...
Tv's picture is messed up.
Symptom: Blue convergence off, bowed inward at the top and bottom with No blue vert movement.
Cause: Replace IK05 (STK392-110) and RK54 (1.5 ohm/1W) and converge. RK50(2.2 ohm/1W)
Sep 20, 2009 | Hitachi 43FDX01B TV
TV picture won't open.
The vertical sync circuit has gone bad...you'll have to have it repaired if you want to keep it
Jan 03, 2009 | Televison & Video
Osprey-230 video capture card distorted
you must connect all cameras to solve this problem.if your capture card supports e.g. 4 cameras and you are only 1,2 or 3 connected the image can be poore.your video card has nothing to do with this.
Aug 28, 2008 | ViewCast Osprey-230 (OSPREY230) Video...
Hitachi 53SBX59B 53" Rear Projection Television Logo
51 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
