Question about Garden
I am not getting any spark at the plug. it started once but now no spark.
    President:
  • 2,220 Answers
Replace the plug and retry (<$5), if no better try this.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Sep 01, 2010
Why wont start
Ok well there is only two things that make a combustion engine run! If you are getting gas to the fuel rail and it has adequate fuel pressure at the rail then you have a spark problem! Pick up a spark tester( looks like a plug wire in a way but has a light ) Plug it into the first plug on the right side of the motor,(# 1 cylinder) and have a friend turn over the motor. There should be positive spark and the light indicator should light as a constant . If it is intermittent in any way than spark is why u will not start. Then on these years I always start with a new coil or coil packs depending on your type of engine! Hope this helps!! Just my opinion and I could be wrong ! Good luck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jeff_24365d731679262d
Feb 19, 2015 | 1999 Chevrolet Silverado 1500
I have a poulan leaf blower that will not start.it sat for 2 years started once for about a minute
get a new plug and then check for spark. a spark checker is a better choice...and since I would be more inclined to believe you're not getting any fuel replace the carb and fuel lines. it's a waist of time trying anything else. just because you have fuel in the primer DOES NOT mean gas is getting to the engine. If you DO NOT have spark, but you have fuel, your spark plug WILL be fuel fouled (soaked with fuel)
Oct 16, 2014 | Poulan Garden
2001 Kia sportage crank but won't start
Make sure you're getting spark at the spark plugs. You can do this by arching the plug to the engine block Just Google "how to test spark plugs". If there is a spark then it could be your timing, which is what happened to my wife's car, once we replaced everything, this was the final thing which solved her problem.
Aug 25, 2014 | Kia Sportage Cars & Trucks
I left my gas Ryobi Line Trimmer out in the rain on accident and now it won't start. I pulled the spark plug out and it looked fouled so I replaced it. It's still not starting with the new spark plug. I...
Try removing the fuel, remove the spark plug and give a few pulls to remove starter fluid from the cylinder, once completed attach your spark plug and check spark, reinstall plug, add fresf fuel to the tank and try staring with normal cold start procedure. Does it have good compression?
Sep 27, 2013 | Ryobi Garden
My daughers 1999 altima ran out of gas, we put gas in it, & it still wont start, we replaced the rotor cap & spark plugs, it getting plenty of fuel but still wont start, what can it be?
Hello you will need to replace the spark plugs you quoted it is getting lots of gas so your spark plugs are wet.disconnect your battery while your replacing your spark plugs once finished replacing the spark plugs reconnect the battery now try to start it should start up.
Jan 10, 2011 | 1999 Nissan Altima
Spark Plug gets wet too fast
Air filter may be blocked and inspect exhaust baffles and clean.
Apr 29, 2010 | 2000 Gas Gas EC 200
Why would a suzuki 4-wheeler not start. I have
Did you change the fuel filter? Is there a way to confirm that you're getting gasoline to the carburetor? If it fired once it should mean that you have spark to the plugs but there could also be a short in the kill switch circuitry that kills the ignition system. Pull a spark plug and put it in the spark plug wire socket, ground it against the motor and crank the engine and see if you're getting a good spark. Ensure that the air filter isn't dirty.
Nov 06, 2009 | Sport & Outdoor - Others
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
I need to change the spark plugs and i dont know where to start?
Go through your spark plug wires and mark which plug it is on. Once you have done this then you can pull the wires off each spark plug. Once the plug wires are off take a spark plug socket and gently apply some pressure to loosen the spark plug. Once its loose you should be able to reach down and remove the plug by hand. Once you have the plug off grab your new plug. Make sure it has the correct gab setting for your engine size and then install the new plug. once you have the new plug in gently snug it down. Do this with the rest of your plugs. Once all your plugs are in place and snugged down then put your plug wires back on each plug (This is where the labeling comes in handy). It is also a good idea to get a good set of plug wires and just replace them while you are at it.
Apr 01, 2009 | 1987 Ford Bronco
2oo3 mazda rx8 wont start turns over and is getting fuel started once and ran for 3 seconds then nothing
Have you checked if it has spark ? Check the spark by removing a sprk plug and connect it to the wire. Place the spark plug agains a groung. Then have somebody crank the engine. It should have spark.
Nov 12, 2008 | Mazda RX-8 Cars & Trucks
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
