Question about Siemens Gigaset 8825 Cordless Phone
When i try to check my messages from a remote location, as soon as I hit the star key twice, as I always have, I receive a message that says "remote access not allowed". i have a siemens gigaset 8825, and i've never had this problem before.
  • 1 more comment
  • bruce1506 Sep 01, 2010
    i've tried this, however it doesn't work. the manual instructs me to hit * twice, as i've done for years. ive never received this "remote access not allowed" message before. as to the security code, i never get far enough to have to enter it.
    what about the display issue?
    so thats all that can really be done then?  thats what i thought.
    hi, these are all things i knew enough to do before i contacted you.  this didnt work.  any other ideas regarding the display issue?
  • 944 Answers
Just reset the Siemens Gigaset 8825 to its factory settings and every thing will be solved.It will ask for Pin no.If you have changed the pin no give it else give the default pin no 0000
If you had forgot the pin no :
Steps to reset the PIN on the 8825 back to 0000.
To reset your pin on your base station, you push Menu, scroll to System Settings, DON'T PUSH SELECT, push * 6 5 # That will reset the pin.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 01, 2010
    Yes this is the only solution if you even take it to the customer care they will do this only.
    There is no other go.When internal firmware is corrupted you have to go for reset option...
    Thank you
  • 11,896 Answers
Many phones you just have to press the * key or the # key one time. Check the settings to make sure remote connection is on and that you know the correct security code
  • Nate Stansfield
    Nate Stansfield Sep 01, 2010
    the display issue would be a problem with the display screen or circuit board. It very well could be an electrical issue. Maby this is why the display and the messaging service is not working.
  • Nate Stansfield
    You will need to get a hold of an ohmmeter/voltmeter tester and test some of the capacitors in the unit. Look for any that are swelled up or have burn marks on the main circuit board. This is a sure sign of bad capacitors or resistors. Each one has an imprinted number of it's power rating so you can match it up with your tester. Check that there are no broken or shorted wires to the display first. If not, then test the capacitors and resistors. Chances are that there are bad ones. It is rare that the LCD itself would be bad but it could happen. Usually it is a bad connection or faulty electronical component such as capacitor or resistor providing power to the display. A faulty IC could also very well cause this problem. It is the square or rectangular chip on the main electronical board. You can try lightly tapping on this to see if the display full lights up. Look around for any loose solder joints or joints that are not fully connected to both of it's surfaces. If you see any, try re-soldering them to make a better connection.
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
How to use romote code
Usually the phone sets are set to recognize a pound sign # or star sign * remotely. You may also have an access passcode (usually 4 digits) - there is a default with each phone set. Make sure you call from a touch tone phone when calling remotely. You can call from a cell.
1. To start, Call your home phone and as soon as your answering system answers try hitting one of the above mentioned keys. Try the star sign first - that should kick you into your voicemail system. Then most likely it will ask you for your passcode. From there it will work the same as if you were at your house. (You should always change your default passcode to a different number as most phones are sent from the factory with the same code.
Nov 12, 2012 | Uniden EXA15580 Cordless Telephone
My nokia N73 always memory full. even i deleted alll the datas and messages. i cant even received text messages. what will i do?
Just Format by using this 100000% verified..
Press and hold 3 keys i.e. Green, dial key, *, Star key, no. 3 , key on keypad and then press the power on/off to switch on the phone.Examine the battery backup of your phone. Remember, do not let go the 3 button i.e * + 3 + green just press and hold keys until you see a formatting word screen shown........But in N series don't release the three button until the time set shown . original system and factory setting has also done automatically.There is no guarantee coz it might not work with some phone.............................................Try and Enjoy
Sep 27, 2010 | Nokia N73 Cellular Phone
What is the security code for kdc-891
You will need a Kenwood RC-410 remote control.
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Jun 01, 2010 | Kenwood KDC-X891 CD Player
N5530 -Cannot send and receive text messages
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Apr 14, 2010 | Nokia 5530 XpressMusic Smartphone
I m trying to program my RC64 remote for Direct TV and as soon as I press the mute/select buttons in order to put in the codes it says that my remote isn't programed for the TV yet so I cannot press that...
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Jan 09, 2010 | RCA DIRECTV Satellite Remote Control
I have a Directv RC24 remote control. I am trying
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
Text messages type in very strangely
When ready to type the message pulse #key for 2 or 3 seconds and turn Prediction OFF and problem solved. It works for my Nokia 3555.
Dec 19, 2008 | Cell Phones
SAT button it does not work, you can not turn on or off the DISH
First press the SAT button at the top left hand side of the remote and release. Now try changing channels. If this did not work press the menu button twice on the receiver. It will usually be behind a pop open door on the right of the receiver. I f your receiver does not have these buttons you can access the system info screen by pressing the power button on the receiver while holding down the arrow left or right key.
Once you have come to the SYSTEM INFO SCREEN press and hold the SAT button on the top left side of the remote until all lights across the top light up. Then key in a two digit number e.g. 01-16 and press the #key. then press the record button and the remote address for the location you are trying to control should change to the number you keyed in. If this is the second location tv that was giving you issues exit out of all the screens on the receiver location tv and go to the other location and try the remote. If it is the tv where the receiver is located then you should now be able to use the remote to maneuver the yellow cursor across the screen. If you need further assistance please let me know. Thanks for using Fix Ya.
Dec 11, 2008 | DISH Network IR Remote Control
Pan Tech Duo... New Texts and Silent
After you read a message, always hit the return/back key to get you back to the main list of messages. This phone automatically returns you to wherever you left off last, so if you don't hit the return key, your last message read will be what is displayed when you hit your message key.
No, your phone is not defective, you need to change your settings.
In your menu, go to SETTINGS, then PROFILES. Scroll to the profile you are using then select EDIT. Under each profile you have the option to select how your phone handles any alert you receive (i.e. for calls, messages, texts, etc.) You have several options some of which are silent, silent and vibrate, vibrate only.
Personally I want my phone to vibrate when it's on silent so that I know I'm receiving a call or text. You can choose another option though.
Jul 31, 2008 | Pantech Duo Smartphone
Siemens Gigaset 8825 Cordless Phone Logo
307 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
