Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Sep 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a lift master and it will not open from any control lite comes on but no sound from motor greenled appears to flash 5 times unplugged and reestablish power with no results
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Sep 01, 2010
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1458355
Points
8183
The code for 5 flashes is RPM sensor or motor overload. The RPM sensor is a small printed circuit board just in front of the motor.
1helpful
2answers
Lift-Master 1260, circa 1993. Today it won't open or close. Just lights on and a quiet clunk sound when I press the remote or wall button. Chain doesn't move. Safety sensor lights steady green. Unplug for...
29 years is along run on an opener. Personally I would replace it and not spend any money trying to repair it. You can try and find a control panel, or buy a new opener for $200.00 at HD. you can leave track in place replace rollers from new opener box.
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
I have a lift Master Model 2280 garage door opener. At times it works perfect other times it will stop going up or down. Sometimes while it is not being used the lights will go off and then come back on...
Sounds like loose connections. Unplug, remove the cover and be sure all connections are tight and secure. While doing this be sure there are no burnt connections or burns on the PCB. Replace cover, plug in and it should be OK.
4helpful
I have a Chamberlane Lift Master Professional I went to open it yesterday and it would not open. When the button is pushed the unit just clicks and the controller light is blinking 5 times then pauses and...
The code it is flashing is "RPM sensor or motor overload." It is not a door sensor problem. The RPM sensor is a small circuit board just in front of the motor.
I have a Liftmaster Model 2500 opener. It is about seven years old, and worked great until recently. It has stopped working, including no lights at the Multi-function door control. If I unplug the...
THIS IS PROBABLY CAUSED BY A SHORTED WIRE.
OR A BAD WALL CONTROL.
DISCONNECT WALL CONTROL & TEST.
IF STILL NO RESULT DISCONNECT WALL CONTROL WIRES AT THE POWERHEAD & TEST AGAIN.
REPLACE WIRE OR WALL CONTROL.
HOPE THIS HELPS
1helpful
2answers
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
I have a Lift Master 1/2 HP Prof. line and remote will not open door but from inside on wall it will if you hold the button for about 5 seconds and then hit the button again it will open door. There is a...
If you have the 3 button wall control you need to press and hold the button with the lock icon for 3 seconds.
You may also need to new wall control. You shouldn't have to hold that button in nor press a second time.
3answers
Lift-Master garage door opener stopped working
The motor will probably need rewinding.
Professional job. Don't forget to take the condensor with the motor.
Or alternatively, if money isn't a problem,, get somebody out to look at it.
There ya go:)
1helpful
Xantrex 2412 will not open my Chamberlain Lift Master Prof. door
That must be a pretty big door opener. Problem is probably the motor's starting current draw. Most AC induction motors pull 5 to 7 times their rated running current when starting from a dead stop. (about 7,820 watts) That's much more than the surge capacity of a 2.4 Kw inverter. Sounds like you need a bigger inverter or a smaller door motor.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
