Question about RCA F32648 32" TV
OLDER MODEL RCA HOME THEATER PICTURE AND PICTURE
I have a problem with my OLDER MODEL RCA HOME THEATER PICTURE AND PICTURE TV WITH GUIDE PLUS When I turn the unit on, it scrolls between the Guide Plus and the menu more of the menu than the guide and won't allow me to change channels or control the volume. Some days it won’t allow me to turn it on at all with or with out the remote. The only way to turn the TV back on is to hit the Volume down button on the TV it self. But when we have to turn it on that way a sequence of red numbers appear on the bottom of the screen that are highlighted in blue. When that appears you can’t even control the TV unless you hit the CH up button. In order to turn it off you have to hit the CH down button on the TV when the menu is not flashing on the TV or just unplug it. On top of every thing else the TV will mute it self for hours while the menu is jumping from on option to the next. Please can you help?
Hi Unykue,
I am an electronics technician who just happened have been given the same set as you because it was giving the previous owner the same problem. Since I am confident in my trade, I took the set and diagnosed noise in the remote receivers input to the cpu.
What this means is that a capacitor( or something) wasn't working properly and was either not filtering the noise out or it was introducing noise into the data stream that controls the TV through your remote control.
My fix was to essentially cut out the entire remote control input to the TV. Since I have a directtv box to give me remote control, I don't care if the TV's remote works anyway.
The way I did this was to open up the unit and find the front I/O board were the buttons meet the switches for power,chaennel, volume, etc. On that board there is a plug with white wires and one black wire. The two wires to cut are the one next to the black wire and the one all the way at the other end of the black wire. These two wires are easy to splice back if you do not like the results of this procedure so that there is really no risk of damaging your set. If you wish to verify the proper wires to cut, they are the two wires that come from the IR receiver's side of the board YET DO NOT GO TO THE OTHER SIDE WITH THE BUTTONS! There is one wire that does indeed go to both sides.
This may not be a perfect solution but it is free. I hope that this will help someone out there.
Len
Posted on Dec 09, 2008
Rca crt tv guide plus wont turn off for several minutes after turning on tv and dish. I have a satellite dish so removing the zip code causes picture to become snowy and whit horizontal and vertical s
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 17, 2014 | RCA F25432 25" TV
RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Dec 26, 2009 | RCA P52937 52" Rear Projection Television
Remote control ceased functions to RCA Home Theater Guide Plus
Frist of all your main problem is that you have a rca. You probley have some bad capastors that have lost there value. You probley will have to take to a shop for repair.
Mar 05, 2009 | RCA F32648 32" TV
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Guide plus rca tv how do stop it from coming up when turning on tv
I have a rca tv guide plus that has the back pannel lights on, but is unplugged, what is the problem?
Jan 04, 2008 | Televison & Video
Users Manual
Can not take television off widescreen.
Nov 06, 2007 | RCA 32V550T 32" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Guide Plus
Not that I could find in the owners manual. Push guide or clear to exit.
Oct 04, 2007 | RCA F32669 32" TV
RCA F32648 32" TV Logo
1,115 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
