Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Generic problem for all Car Amplifiers
Power Acoustik G320-2 Gothic Series
Wes_2008 on May 09, 2008
So I got this from my bro-in-law; its a whole kit...amp, box, woofer etc. I have it wired up just like my older bazzoka tube; actually I have it wired up just like he had it when it WORKED but now I cant even get it to power up. Am I missing something here?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 10, 2008
Somewhat Helpful)
pbabin
Rank: Guru
Rating: 89%, 340 votes
If you're geting no lights on the amp, you need to confirm that you have voltage at the amp. If you haven't done so yet, check the on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Was this helpful?
Yes
No
Related Problems
Punch amp 401s. Transistors TC7,TC8,TC15,TC16 Type, NPN or...
the last answer was great and very helpful but i have 1 moee...
is a rockford fosgate punch 40i dsm amp bridgeable and if it...
Can you Help with these Car Amplifier problems?
in the diamond audio d6 1500.1 there...
Solve
in the diamond audio d6 1500.1 there is a crossover board whit two 16 pin chips in it and they... (More)
do i have to take the back plate off...
Solve
do i have to take the back plate off again cuz theres no reset button near the plug in fuse???
I have a 2002 corvette, the base...
Solve
I have a 2002 corvette, the base does not work on the Bose system....what could the problem be.
my amp was working fine for about...
Solve
my amp was working fine for about three hours when i realized the speaker box had turned off and the... (More)
maytag dryer drum not turning -...
Solve
maytag dryer drum not turning - suspect belt - don't know how to get to it.
Sponsored Links
Describe your Car Audio problem:
Select a Category:
Top Car Amplifier Experts
Rank: Guru Guru
Solutions: 9503
Experience: Do it-your-selfer for a lifetime, 35 years of electrical and mechanical professional exp.
Ask Me
Find more Car Amplifier Experts
Top Audio & Video Equ... Repair
(888) 737-1752
We can Fix 3 Red Light Errors,One Red Light...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
