Question about Health & Beauty
The drive shaft from the motor to the gear system in the transaxle of my pride legend classic xl-8 is broken , i can afford to by a new transaxle ,i need one thats being broken up . is there anyway i can find one being broken up to rob the part from another scooter thats finnished its life . barry bassnett
  • 103 Answers
SOURCE: Performance/Range issue with Pride Legend Classic
If only one wheel turns then it sounds like the transaxle is bad. They are a sealed unit and cost around $1000.
Posted on Mar 09, 2009
  • 175 Answers
SOURCE: my pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
Posted on Aug 28, 2009
gewiz
  • 1263 Answers
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Posted on Oct 01, 2009
gewiz
  • 1263 Answers
SOURCE: how do i remove the pride legend classic xl8 seat
hi, be careful here as it can make your back ache,
now there is a lever to the right of the seat, pull it up towards you and
turn your seat 90 anticlockwise, so the seats not facing the control panel, at right angles, you should now be able to lift the seat , take great care here if you have back problems in the past as some seats are quite heavy.
Regards
GeWiz.
Posted on Dec 13, 2009
Testimonial: "thanks"
gewiz
  • 1263 Answers
SOURCE: My Pride Legend 3 wheel scooter will not go
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Posted on Feb 19, 2010
MY PRIDE CELEBRITY XL SCOOTER JUST STOPPED IT IS IN FREE WHEEL AND WONT ENGAGE IN TO GEAR
Sounds like a blown transaxle. If the scooter has had heavy use or a heavy rider this would not be uncommon after 3-5 years of use.
Mar 13, 2014 | Pride Celebrity Xl 4 Wheel Scooter
The kids drove my Pride Legend XL through a puddle. I doesn't go anymore. I need a technical Reference Manual with schematics. I could fix it myself or......? Batteries are fully charged. No...
I had a similar problem with my Pride Legend XL when I drove it
through a puddle accidently and some water splashed up underneath
the motor controller. It would buck or go then stoo without any warning
as the electric brake was applied. Had to take the seat off and use a
hair dryer on the controller connections to dry them out. It doesn't
seem to take much water to make these inoperative. After thoroughly
dried out with a hair dryer..no more problems like that with it.
Oct 27, 2011 | Pride Mobility Products Pride Legend XL -...
My dad has a pride celebrity xl scooter and keeps getting a noise similar to a rubbing noise from rear right wheel while driving, it sounds once for every rotation of the wheel, iv checked that nothing is...
The noise you are describing usually comes from the trans-axle and not from the motor/brake. Motor brake noise is usually continuous. Sounds like the trans-axle may be slightly bent on the right or rubbing internally. The easiest way to identify this is to block up the scooter and remove the rear cover. Look and listen to all the drivetrain components while the scooter is blocked up and running. If you hear rubbing at the end shaft as you describe you can try the following:
Loosen the trans-axle metal mounts that clamp the rubber sleeves over the trans-axle
Spray the rubber sleeves with silicone.
Re-torque the clamps after checking the alignment.
An overtightened or misaligned clamp can sometimes cause noise.
The brake/motor/transaxle has a prorated three year warranty so you should go through a Pride dealer for warranty repairs.
Sometimes you can get a noisy wheel on the key and key-way of the trans-axle shaft. It may be worthwhile to pull both rear wheels lubricate the shaft key-ways and keys and re-install the wheels. This can sometimes quiet a multitude of noises from the trans-axle. Depending on the age of the scooter you can do nothing, replace the brake/motor/transaxle parts individually, replace the complete assembly. I like to replace the entire assembly under warranty so there are no future problems. The rest of the repair depends on your insurance coverage or budget. Hope this helps.
Nov 30, 2010 | Pride Celebrity Xl 4 Wheel Scooter
My scooter when I press the throttle to go forward it like breaks or stops. I have a Legend XL. It goes OK in reverse but, when you press to go forward it breaks like bad gas.
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
I have a pride legend classic xl8 and the spline drive from the motor to the diff has snapped, where can i get a new one or do i have to get a new rear axle complete?
hi, can you send me a picture of this so I can assess the damage, I have repaired many gearboxes so it not a problem.
helpNOSPAM@gewizrepairs.co.uk
just remove the NOSPAM from the emaill adress so it correct.
Regards
GeWiz.
Dec 10, 2009 | Pride New Mobility Legend 4 Wheel Scooter
I have mislaid my Legend Classic XL8 manual & wish to know all the flash error codes
This page has a link to the users manual near the bottom:
http://www.cheapest-scooters.co.uk/8mph/pride-legend-classic-xl8-mobility-scooter.html
Aug 21, 2009 | Pride New Mobility Legend 4 Wheel Scooter
I bumped into a wall and now the steering column will not adjust
I really need to see a photo of this problem, a close up picture of where you think it broken
Apr 06, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Jan 20, 2009 | Pride Legend 3 Wheel Mid-Size Scooter
Health & Beauty Logo
52 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
