Question about Intel SCB2SCSI Motherboard
Giga pro motherboard
I have a problem making my motherboard come up. The board powered but its not coming up, and I have checked the processor and the RAM. There are two slot for RAMS : SDRAM and DDRAM
    Sergeant:
  • 221 Answers
Replace the power supply with one that you know is good, see if that helps. If not comment back and I will continue to search for solutions.
Posted on May 10, 2008
Asus m4n78 pro no starting problem
check out power supply then cpu fan is running and video card works and ram is in all the way make sure that all the power plugs are in the right places as well on the board
Mar 15, 2013 | ASUS M4N78 PRO Motherboard & AMD Athlon II...
Board runs shows to be on runs but no beep and no display. No beep even when processor or memory removed.
The problem is in the processor or in the board to check first change the processor sutable for the socket and switchon the computer still the computer doesnt work check the secondery power supply thats four pin from the smps to the motherboard check all the FET and the capacitor in the powersupply also the 32khz crystel and the 14.182khz crystel and the clock ic
Mar 29, 2011 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
Before booting 3 long beeps 10 sec silent then 3 long beeps and so on
This is an issue that one of the devices is not properly seated on the board or it is not detecting them correctly.
To fix:
1. Remove all devices from the board. All cables coming from Hard drive/CD-rom. Remove the RAM and processor. LEAVE TH E POWER SUPPLY CABLES CONNECTED TO THE BOARD.
2. Re-seat the processor on the board.
3. Re seat the memory on the board.
4. Now re-seat the video card making sure that you push it firmly in place. Connect a monitor to the video output.
Try and boot the computer. If it boots and you see output on the screen then the issue is fixed.
If if does not boot you have a problem with one of the following: RAM, Processor, Video Card, or motherboard.
Oct 30, 2010 | Asrock K7VT4A-Pro Motherboard
I just bought a new motherboard; basically new everything, well on my old motherboard there was a CPU and on this newer better motherboard there is not a CPU. Do I need to got one? What is a CPU exactly?
first, make sure that the new mother board support the old Processors, ask the M.Board supplier about it (or google it) , and make sure you know the old processors type.If you wasn't really sure, just remove the old Processor from old M.Board, then check for the ID (such as Pentium 4, Pentium D, etc ) on top of the processor.
If the new M.Board support the Processors, then you can re use the old processors, if don't, then you don't have a choice, buy the new one that match with the new M.Board specifications.
Hope you understand.
Feb 22, 2010 | Office Equipment & Supplies
I reinstall win xp and i need the followings
I cannot determine the make or model of your motherboard you are currently using as you have only specified the Processor's make/model.
I have compiled a list below of common motherboards that work with the AMD Athlon XP processor (1500+)
Please choose from the links below one that best matches your motherboard; (These are driver links for the motherboard)
OPTION1: ---- MSI ----
K7T266 Pro
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=288
OPTION 2: ---- Gigabyte ----
VIA KT266A
GA-7VTXE
* Instruction to download product image :
Right click on the product image, choose "Save Picture As..."
* The product picture above is only for reference.
* GIGABYTE reserves the rights to alter product specifications at any time without notice.
" href="http://www.giga-byte.com/FileList/Image/motherboard_productimage_ga-7vtxe_big.jpg" rel="pic" jquery1239713741655="4">motherboard_productimage_ga-7vtxe_small.jpg
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=1310&ost=xp#anchor_os
OPTION 3: ---- ASUS ----
A7V266
http://support.asus.com/download/download.aspx?SLanguage=en-us
Thanks
C
Apr 14, 2009 | AMD Athlon XP 1500+ , 1.33 GHz Processor
Monitor goes into 'Power Saver Mode' on boot up!
You need to upgrade your motherboard BIOS to the latest version (V.5a) to support your DUAL CORE 2.5Ghz processor... that's the problem.
Visit:
http://tw.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2779
http://tw.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=2779
Jan 07, 2009 | Corsair Memory Corsair VX 550W Ultra Quiet...
Upgrading processor
Do not know much about mac but can you change settings on M/board by using jumpers to upgrade bus speed etc or in BIOS
Aug 13, 2008 | Giga Designs G4, 1.3 GHz (5-1213c)
Motherboard detects nothing
anniegms, I had the same problem with a new Asus board running a Dual Core Duo Quad processor. The boards BIOS was not updated to handle the Dual Core Duo yet. I had to switch processors to a P4. Use a different PC to make a BIOS update disk. Update the BIOS and switch processors back. But I had all the same symptoms of yours. However I did/do have a PCI-E XFX Fatality (Nvida) based graphics card. I would check or swap processors, it sounds like the board is waking up but not the processor. Just my thoughts.... PCdok
Oct 21, 2007 | ASUS P5GD1-VM Motherboard
Logo screen, but no POST test
Try removing all unneeded hardware leaving only the core components needed to see your board post (processor, memory, motherboard and external video if your board doesn't have onboard) see if it now posts. check to make sure your hardware is installed correctly (memory is seated and processor & heatsink are firmly inplace) Is your new board bigger than the old one? does it make any contact with the case behind the board causing it to short? You could also try your processor in another board. Good Luck
Dec 21, 2006 | Intel D845PEBT2 (KD845PEBT2PAK10)...
Intel SCB2SCSI Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
