Question about U-Line 15WC Wine Cooler
My Uline wine cooler model ULN-75WCSS-00 will not start when plugged in. Trying to figure out if there is something that can be done to get this fixed (relay?, Redistorr? etc.) Do not thik it is the compressor
  • 286 Answers
SOURCE: uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Posted on Jun 15, 2009
  • 286 Answers
SOURCE: Describe your uline wine cooler Problem
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Posted on Jul 20, 2009
meBNme
  • 334 Answers
SOURCE: Want to purchase relay. Can't find part locally.
The best thing to do is go to your local appliance parts warehouse and match up the relay with what they have in stock.
Be sure to briung all relevant info you might have on the unit.
That way you can ask for the RF-5600-01 to compare it before purchasing. Thats exatly what a service tech would do if you called one, only they will charge you 50 to 100 bucks to do it.
Posted on Aug 25, 2009
  • 286 Answers
SOURCE: Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Posted on Oct 08, 2009
  • 17 Answers
SOURCE: wine cooler (uline) not cooling
Make sure that you have enough air flow around the unit and that the grill on the bottom is clean and free of dust/pet hair ect..also take into consideration of the location of the unit... make sure it is not next to a heated appliance like a dishwasher or range. and remember that it is not a frig it is a wine cooler so it will not get really cold.... if it has a glass front make sure it is not sitting in direct sunlight for extend periods of time as this will cause the unit to run excessively. I hope this helps.. I hate warm wine..
Posted on Nov 11, 2009
Uline 75WC Wine cooler: light works but fan and compressor do not come on. Wire cnnections are fine.
Does the compressor vibrabte? If not, the PCB isn't working and should be replaced or worst case is your compressor burned out.
Jan 22, 2012 | U-Line 75WC Wine Cooler
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
Wine cooler #ULN-75BWC-00 motor seems to have shut off and no longer cooling. Please advise possible issues & parts to be replaced. Unit about 7 yrs old.
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
Feb 15, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
Oct 06, 2009 | U-Line 75WC Wine Cooler
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Jan 03, 2009 | U-Line 15WC Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
Nov 01, 2008 | U-Line 75WC Wine Cooler
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
U-Line 15WC Wine Cooler Logo
637 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
