Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Pulled carerator to clean ,put back on and engin run wide open , think one of the is missing
    Scholar:
  • 97 Answers
Check to make sure the governor was reconnected it will be a arm that goes behind the adjustment plate that's acts as a support for the barb it will have a spring and can come lose easily trying to install the carb if it comes lose the engine will run wiled and race hope this helps
Posted on Sep 01, 2010
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
1998 Virago 1100, today I pull my spark plug wire to find the right size spark plug socket. within in a few minutes I learned I had to go pick my son up from school. I forgot about the wire off. And it was...
I am assuming this is a motorcycle?.. By running the engine with no spark plug wire connected you are inviting that cylinder to be filled with unburnt gas... it accumulates and makes it hard for the engine to turn over... and it could damage your engine.. First.. put two NEW sparks in..see if that fixes it!! ..if not...
Leave both spark plugs out....turn the engine over (throttle closed!!) so you clear out all unburnt gas. reinstall the plugs and see if it runs ok.. great if it does.. IF NOT.. time for a compression check to see if you damaged anything in the cylinder that was "disconnected". ..Beg, borrow, buy,a compression gauge... or pay a professional to run a compression check.. you should pump around 150psi + with the throttle wide open. (remove the other spark plug wire because you do not want the engine to start!).. if the compression check is good, you need to take it to a professional mechanic for further diagnosis.
Jun 06, 2017 | Cars & Trucks
SUBARU EX21 GAS ENGINE RUNS WIDE OPEN WILL NOT IDLE
adjust jet to full close then open quarter turn , check manifold for leaks .sounds like the gasket leaking not tight ,
Apr 08, 2014 | Garden
I have a 2006 pacifica the throttle pedal likes to stick sometimes now the engine runs rough and smells like something is burning had the 02 sensors changed cause the check engine light was on even after...
Let's fix the sticky gas pedal. Loosen the the two screws on the side of the ait cleaner, lift the front while pushing forward and the cover will come loose. Loosen the two clamps on the hose that goes to the intake and pull off. Take a bunge cord and hold the throttle wide open or have someone hold the gas pedal down to the floor. Take throttle body cleaner and spray it on a clean old sock or rag and wipe down the whole inside by the opening and the flapper valve both sides and you're done. Now take it back to the guy that replaced them and you should have a warranty. It the engine is missing you probably destroyed the converter and they are new 900 dollars and after market 250. Have the codes checked for free at the auto parts store for free. If you live in an area that has alcohol in the fuel dry gas is useless all it is is alcohol and you get 10% alcohol every time you fill up. It was different in the old days when we had pure gas
Feb 17, 2014 | Chrysler Pacifica Cars & Trucks
1987 Ford Bronco 2 2.9L V6 Missing on one cyl.
Its possible that injector is sticking open or weak enough to be staying open too much - flooding that cylinder.
Jan 19, 2014 | Ford Bronco II Cars & Trucks
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Difficulty starting Poulan 2250 . . .
hey pete
This is easy, prime bulb 5 to 7 times with choke lever full out. Pull string, once engine starts turn off choke and pull string again. ( throughout process do not pull trigger )Engine should start, let it idle 30 seconds, then finally pull trigger to rev up engine.
Jul 03, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke engine starts and runs fine in neutral try to accelerate under load and it only will pull about 2800-3000 RPMs and wont go any faster it will rev fine in...
Reving in neutral does not mean the same thing as under load. If you need to pull 4500rpm under load and for an instant the load was gone, you would probably overrev to 6500. With the cover off and motor not running move the throttle to full forward. Look at your carbs and see if the throttle plates are wide open. If they are not all wide open take it back to the dealer. The throttle adjustment is off. You need the full range of travel from idle to topend.
Jun 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Engine is racing
Yeah I think you put it back the wrong way. But its not a big problem.
I believe that the reason why it is on "High Rev" is because your drum /valve is not sitting in properly and is pulling the throttle cable.
Just dismantle it slowly and have a look inside. Your throttle cable shouldn't be stressed when putting it back.
Good work.
May 08, 2009 | Watches
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
139 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
