Question about Watches
My aunt's watch is a timex expedition. it says to push the reset button after changing the battery and we can't find one. The clock works but the alarm doesnt. She had the battery replaced at walmart and they cant find one either.
  • 831 Answers
I am sending you a link to instructions for a differnet Timex, but it is basically the same conccept. This link has pictures which will help you figure this out. If you still have troubles....I highly recommend you take to a QUALIFIED jeweler besides Walmart.
http://www.userinterface.com/instruc/timex/timex.html
Best regards. Jewel
Posted on Sep 01, 2010
I have timex expedition watch model T49664 with altitude. It works well for last 3 years then battery died. Twice i change CR2430 even once in timex showroom. But the battery dies in 15 days. Plz help
After changing the battery press and hold all the buttons at the same time to reset this will make the watch and battery works properly so that the battery wont drain easily. I hope I have been helped you.
Nov 09, 2014 | Watches
Hello, this may sound silly but I just bought a Timex Ladies watch and I can set the clock but it's not actually turning on when I push the side button in? It's a new watch direct from Timex so I...
mcdevito75 here, A brand new Timex quartz watch will come with a small piece of plastic just under the crown to keep the battery form working the watch, simply remove this small piece of plastic from under the stem (winder) push the stem in and your Timex will work. If your timex is push button you may have to hold down the Mode 2--3 seconds to see display.
Aug 02, 2010 | Timex 27191 Wristwatch
CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 09, 2010 | Timex Expedition 84601 Wristwatch
HOW DO I CHANGE THE BATTERY ON MY TIMEX 40691
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are so many applications use of the manual will be mandatory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Feb 01, 2010 | Timex Expedition Camouflage 40691 Wrist...
Timex expedition problem
You probibly need to have the anologe serviced. It isn't like the old days when watches had a mainspring which, when you wound it the gears would push by anything that got in the gears way because of the pressure form the mainspring. Now with quartz watche ANY little thing ( dust sooo small) will stop the gears from running. I would take the watch to a reputable watchrepair and have them check the battery. DO NOT ask them to sell you a new battery just CHECK it. If you get a new battery, it the watch probibly will run good again for about 3 weeks , and then start acting up again, because a new battery might have enough power (at first) to get by the watches problem untill it uses some energy up. But if your battery is bad that to could cause this , but that is highly doubtful that is the problem.
If you still have a problems please let me know I will be glad to assist you!
Aug 18, 2008 | Timex Expedition 84601 Wristwatch
TIMEX MODEL MF13/P8
Press all the four buttons simultaneously your digital clock gets resetted. It worked for me try it out.
Jul 21, 2008 | Timex Expedition 84601 Wristwatch
Timex expedition
HI
HERE IS SOME STEPS FOR YOUR DOUGHTS......
Set the chronograph. Push the bottom left button until you see the word "CHRONO" on your watch. Press the top right button to pick "Lap" or "Split." Press the top right button to start or stop the timer.
Press the bottom left button to see your lap or split time. Press the bottom left button to pause the timer. Press the top right button to start again. When you're finished, press the bottom left button to stop timing. Push it again to reset it your chronograph to zero.
THANK YOU
Dec 12, 2007 | Timex Digital Expedition watch
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Nov 20, 2007 | Timex Expedition 84601 Wristwatch
Watches Logo
226 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
