Question about GE Dryers
I took the my GE dryer DHDSR46GG1WW apart to replace the belt. I don't have a manual and now I don't remember how to put it back on.
  • GE Master
  • 43,501 Answers
Here is the diagram you need...
Fridgidaire and GE Dryer Belt Replacement
heatman101
Posted on Sep 04, 2010
Control panel turns on but dryer won't start. Start/pause button just beeps when pushed. Opened the front panel to the door switch with multimeter. It looks fine.What could be the issue?
your gonna have to go deeper than the door switch,do you know you can't get the blower motor for this dryer anymore,i don't know why they had to have two motors in their dryers?could be a broken belt,computer issues,bad t-stat or thermal fuse,the only way to tell is by checking it out with meter,also make sure you have 240 volts coming to the dryer,go in the back where the cord connects to dryer and check it there,there's no one answer for this problem,you just have to take it apart and start reading out the thermal fuse high limit t-stat,stuff like that,to find out.i remember the first time i worked on this style dryer,it took me around 20 minutes to figure out how to get it apart,some jerk put the control panel screw behind the knob,had to pull the knob off and then remove the screw to get the top off to take it apart lol,and they have a funky belt setup and two motors,i gotta tell you i would never buy a ge dryer,to much just to dry clothes.sorry i can't help you out with an answer,you can go here,put your model number in and see the parts in your dryer
https://www.searspartsdirect.com/model-number/dpvh880ej0mg/0432/0151200.html
like i said,i only worked on one of these style dryers and it is different from regular dryers,if you can't get it open check the control knob,pop it off and as far as i can remember,this was like 8 years ago i removed the screw behind it,then you can get at the screws to remove the top panel to get into it.wish i knew that at the time,thought it was just gonna be a regular ge dryer repair
Feb 19, 2018 | GE Dryers
My belt is broken on my tumble dryer.took it apart and don't know how to put the new belt on
The belt goes around the drum, through the idler pulley onto the pulley on the motor. The idler fastens into several holes on the floor of the dryer.
Sep 29, 2011 | Dryers
My GE DSXH43EA2WW Dryer is making a squeaking sound when running. Tends to get less noisey as the dryer continues to run
Hello
You will need to replace the dryer belt and inspect the belt rollers while you have it apart. If you go to the web link below it explains how to take apart the dryer to replace the belt, it has additional links to pictures and diagrams within the instructions. The first link is for replacement parts with diagrams of the dryer. Here is that link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130504&diagram_id=21844825#d21844825
The next link is the Do It Yourself Article on replacing the dryer drum belt. while you have it apart remember clean the lint and dirt out of the cabinet interior. Here is the repair link:
http://www.applianceaid.com/ge-dryers.html#belt
Jan 14, 2011 | Dryers
How do you put the belt back on? It was making a screeching sound so I took it apart and now cannot figure out to get the belt tight. I have it back on and back together but do not know how to get the...
you have to open back panel of dryer as well as the top. there will be a spring connected to the motor assembly. unlatch it, check your belt to see if it needs to be replaced. if cracked, replace. latch spring and belt should have tension.
Oct 25, 2010 | GE DWSR463EG Electric Dryer
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Harmony not heating
If your getting at least 110 volts at the igniter and its not glowing red ,than replace the igniter.If you have zero volts there you have to check for a bad thermal fuse or a bad thermostat.
Jul 13, 2008 | GE Profile Harmony DPGT750EC Electric...
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
459 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
