Question about JVC C-20210 20" TV
Color on half the screen is faded - JVC C-20210 20" TV
Bottom half of the screen is faded in color
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 20, 2015 | Televison & Video
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Apr 01, 2012 | Televison & Video
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
On half the screen the colors are faded. when a video is watched on the faded half the colors are really bad
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 26, 2010 | ViewSonic VP230mb 23.1" LCD Monitor
My ViewSonic monitor is having an issue with blurring lines. Anything on the left or middle of the screen blurs to the right in a faded color, extremely noticable when I open MS Paint and fill the left...
This is a tipical flyback defect circuit, the lines can 1st appear on top/bottom of screen, then can increase to center. Send monitor to repair center, for check and repair. You can test with a tv test signal.
Dec 11, 2009 | Computers & Internet
Sharp wizard oz-290HII --fading screens
Friend, try to replace the battery. If it doesn't work try to press firmly the LCD connection interface underneath the screen because such unit has lossen connection.use T6 screwdriver to open the unit then slowly firmly press the LCD connector on the interface. Such thing will solve the problem. good luck
Jun 16, 2009 | Sharp Wizard OZ-290
Dull, faded colors when printing
You probably need to replace the transfer belt. Go into the diagnostic menu and perform a half-test. Open the printer and see if the document looks right before it goes into the fuser. Be careful, the toner will be loose.
Dec 05, 2008 | HP LaserJet CP3505DN Printer - Color Laser...
Windows Looks Faded
normally, this indicates that the color settings in Display properties are set to a lower than normal setting
It should be 32 bit true color
Jul 27, 2008 | Microsoft Computers & Internet
COLOR SHADOW
that is called a magnet effect it means u have a strong current some were do u have a cd player or speakers to close surround sound to close if so move them away till it fades
Jul 05, 2008 | Panasonic PT-51HX41 51" Rear Projection...
JVC C-20210 20" TV Logo
18 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
