Question about Lexmark X3470 All-In-One InkJet Printer
Minha lexmark só fica informando tampa aberta logo apos que eu refiz a intalação dela? E quando eu desligo e ligo novamente ela liga diretamente informando tampa aberta e eu não consigo desliga-lá. O que faço?
5 Suggested Answers
adynamite
  • 15 Answers
SOURCE: nao consigo instalar lexmar E210
Hi and welcome to FixYa
Firstly I don't speak nor write in Portuguese but I understood it so my answer is going to be in English, apologizes for that. OK now Lexmark web site says that there are no Windows 7 drivers for that printer (seems to be an old printer). So lets install the Windows XP driver in comparability mode. But first try unplugging the printer (is it USB?) wait a few seconds and plug it back in to see if Windows 7 can install the drivers by itself (remember to have the windows up to date and all the windows updates options turned ON). Then if that doesn't work for you, try the compatibility mode trick.
1. Download the XP drivers ( http://download.cnet.com/Lexmark-E210/3000-2116_4-146099.html )
2. Place the driver installation file on the Desktop.
3. Right Click the driver installation file and select Properties/Compatibility Tab. Select the appropriate options in from the list (in your case choose windows 7 64 bits).
4. Click Apply/OK.
5. Right Click the file and select the Run As Administrator option to install.
That should work if the first option I gave you don't do the trick.
Hope this information was helpful
Sincerely,
aDynamite.
Posted on Feb 28, 2011
Printtech
  • 1087 Answers
SOURCE: ola amigos., existe algum reseter
Quando você diz "reset", você quer dizer restaurar padrões de fábrica?
Posted on Jul 25, 2011
Printtech
  • 1087 Answers
SOURCE: A impressora lexmark e260dn não
O cartucho de toner pode estar ficando com pouco toner:
? Remova o cartucho de toner eo cartucho de toner.
? Shake it dum lado ao outro para redistribuir o toner.
? Reinstale-o e verifique novamente para a condi??o.
Para obter mais assist?ncia, entre em contato com o Suporte T?cnico da Lexmark
  • 304 Answers
SOURCE: como instalar driver para que
Primero debes instalar el driver postcript para ese modelo, si no lo tienes descargalo en el siguiente link. Busca aqui el driver para tu sistema operativo.
http://support.lexmark.com/index?productCode=LEXMARK_E260&page=driversdownloads&linkSelected=node4^subnode3&locale=ES&userlocale=ES_MX
Posted on Aug 18, 2011
ML 1610 no power
tenho essta impressora, samsung ML-1610 e quando liga, ela reinicia mas fica com as duas luzes piscando, uma vermelha e outra verde, o que devo faser pra funcionar normal, o toner ? novo.***.
Digerson.
Apr 26, 2011 | Samsung ML 1610 Laser Printer
Quando ligo a maquina dsm715 ela informa logo o codigo sc322. como faco para resolver?
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
Apr 25, 2011 | Gestetner DSm745 Black and White Copier
Eu estalo minha uebicam nun dia e ela funciona normal no outro dia,no outro dia quando eu ligo o computador ela fica com a luz ligada ,e da error
hello,
the link below is the driver for the model that you have, you have to extract it and install it in you computer and will work w/ XP,vista, and win7
http://www.a4tech.com/driver/A4%20PC%20Camera%20H.rar
thank you for using Fixya.
Mar 03, 2011 | A4tech PK-635 Webcam
Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Dec 31, 2010 | Kodak EasyShare V610 Digital Camera
No puedo entrar en mi correo yahoo
Necesito entrar en yahoo y poder editar mi cuenta y no puedo por que me hacen una pregunta y no me acuerdo la contestacion y necesito entrar ala cuenta
Oct 25, 2010 | Yahoo Mail
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
Have replaced the drum and toner cartridge and am getting an error message "Toner Life End". We think it may be a problem with a sensor and want to try to reset the machine. Can you tell me how to reset...
Vamos abra a maquina, retira o cartucho, do lado esquerdo tem uma alavanca preta (do lado de dentro da maquina), empurra ela e segura, vai com uma chave de fenda e fecha o sensor de tampa aberta q se localiza do lado esquerdo da parte da frente da maquina, apos vc fechar o sensor a maquina ira fazer o auto teste, e vai mostra Toner erro, coloque o cartucho novamente, delique a maquina fecha a tampa e liga novamente.
Feb 11, 2010 | Brother DCP-8065DN Black and White Copier
Meu Tecra 8100 simplesmente nao liga , funcionava , inseri um hd externo , e desliguei pelo memu iniciar , antes eu so desligava pelo power botton.
Há alguns arquivos que faltam às suas necessidades Tecra 8100 para executar, ele trava no botão de menu porque ele está procurando por arquivos de menu e software que está no seu arranque do programa.
Por favor, desligue o 8100, ligar o HD externo e reiniciar novamente.
Ela vai funcionar bem
Nov 02, 2009 | Toshiba Tecra 8100 Notebook
A PRACA DESLIGA NA HORA DO POST SO FICA OS VENTILADORES FONTES E PROCESSADOR
Mi Portugues esta malo pero hablo espanol, pero me parece que su pregunta tiene algo fazer com os vendiladores de frente, los cuales no paran. Quiero ayudarte, pero no podemos gastar tiempo de nada. Puedo por casualidad que me lo tradusca a espanol, inlges o griego? Gracias por su consideracion de nuestro servicio.
Mi nombre es Constantino (arzconst)
May 29, 2009 | Computers & Internet
I need help
a minha canera quando liga fica
com a tela azul e esta escrito q
lens erro oq eu fasso
a lente nao entra mas
mas ela caiu no chao.
me ajude
Nov 04, 2007 | HP PhotoSmart M627 Digital Camera
Lexmark X3470 All-In-One InkJet Printer Logo
313 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
