Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp photosmart c6180 continually powers on and powers off by itself. Have tried power cord options, have tried hitting various buttons in various ways while powered up. Have tried a lot. Any ideas?
  • HP Printer
    HP Printer Dec 15, 2016
    Contact HP for Care at 1-800-585-2494
  • 16 Answers
Contact HP for Care at 1-800-585-2494 Toll Free
Posted on Dec 15, 2016
Perfect! now the power of my printer C8180 is perfect. I am left with a single error due to some incorrect wiring. Scanner I will scan the image being captured but remain black. Have you any idea what happened? you have a photo printer card?
Posted on Nov 13, 2012
I was excited to find these postings about HP printers. My C6150 had similar problems. I opened it up according to suggestions and all went fine. Found 3 caps that were swollen so got new ones at a local supplier. I think I soldered them on ok - not the cleanest job but don't see any significant damage. I wasn't sure about how to tell polarity but it looks like all caps have an arrow-like stripe on one side and all stripes for all caps face the same way so I put new ones that way. Put all back together and all I get now is a whirling sound for a few seconds and then fast ticking - from the inside right where the print head carriage is resting. I can't move the carriage manually. Double checked all connections but still same sounds. Any suggestions? Thanks for great help.
Posted on Jun 04, 2012
  • don7754
    don7754 Jun 04, 2012
    Problem Solver:
  • 10 Answers
Where is a good place to get the capacitors form
Posted on Nov 18, 2011
While installing the HP Photosmart Full Feature Software and Drivers from the HP website, power went out for a few seconds. When power returned the printer was off and will not turn on when the power...
Theres nothing in the drivers that would cause this unless the software was doing an update to the printers internal software
you could try a hard reset
1. Remove all cables, including:
2. Unplug the printer power.
3. Hold down # and 6 on the keyboard.
4. Plug the power cord back in. .
Mar 18, 2011 | HP Photosmart C6180 All-In-One InkJet...
Problem for HP Photosmart C6180 All-In-One InkJet Printer HP Photosmart C6180 All-In-One err oxc18a0201
Try to perform these step as --->
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Aug 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 turns off and on repeatedly booting (looping) error message says to avoid damage use the on/off button when shutting down. do not use power strip or wall switch
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the Printer was having.74b7f9c.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these
Mar 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
Will not power up , power cord checks out...?
for the power problems there is not reset for that.. if that power cable is working fine with the other printer then probably there is some problem with the port on the printer itself..
Oct 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
good luck
Aug 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 all in one
Have an HP C6180 that would not turn on, no power. Unplugged and replugged the unit in the back - no fix. Unplugged the unit at the wall socket, reconnected and I thought I heard a faint click in the power supply. Hit the on button and the C6180 powered up - no issues. Without knowing for sure, possibly the power supply has some type of surge arrest safety switch.
Aug 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
New HP Photosmart C6180
with regard to your problem since you point out that the cause of your issue is your power cord then,  replace another power cord...
Oct 31, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
7,222 people viewed this question
Seeker5211
Seeker5211
