Question about Canon i9100 InkJet Photo Printer
Printing everything pink and yellow
Everything was printing ok, except for some messy black marks that would not go away with the normal maintenance features, these were hairlike and on the side.
i went into the printer and "wiped" some of the residue found on the printer head, the roll bar on the bottom and the messy well in the back right.
now i am hardly getting a print and the black hairy marks still appear.
what to do?
thank you
  • Canon Master
  • 5,568 Answers
If you tried to wipe the printhead, you may have clogged it instead.
The nozzles are microscopic in size and can be clogged by most cleaning materials.
You need something that produces absolutely no fuzz.
My best results have been when the printhead is removed, sprayed with Windex or similar, then blotted with a hard paper towel.
After this, you may have to run the cleaning routine multiple times to restore all colors.
If you are a heavy user of the machine, you may have accumulations of paper fiber that is acting as a wick and depositing ink on the paper while passing through.
I have on occasion had to strip the printer of its plastics, bathed the entire machine in a home-made solution similar to the Windex formula, spray it clear of the solution with distilled water and then allow it to dry for several days before reassembling.
This is obviously one reason I'm retired- can't compete with the cheap labor building them.
Posted on May 09, 2008
Hello there , my question is ok- when i Print or Copy there is more over tone of yellow exampel if it is- RED it comes out YELLOW - and( no) i do not have the( yellow) in the( red )container It...
You'll have to run the cleaning mode a few times,
to do so you'll have to get into Maintenance Mode.
To do this:
Press MENU then * then 2 then 8 then 6 then 4
This takes some practice and you have to press them all within a few seconds.
If the machine doesn't say MAINTENANCE when you do it press STOP/EXIT and try again.
When in Maintenance Mode:
Press 7 then 6, then press 3, then press BLACK START
It will say Cleaning - this will take some time when it's done it will go back to MAINTENANCE
After it's completed try 0 then 9, this will print out a small Print Quality test page
it should have several rows of each color (Cyan, Magenta, Yellow and Black)
if they still don't look right then run the cleaning mode again and then print another quality page.
Continue to do this until the quality is back to normal,
when you're done to exit maintenance mode press 9 then 9 to return to normal operation.
note: this cleaning mode uses up a fair amount of ink, use sparingly
note: maintenance mode is for brother technicians and has some codes that can damage your machine, only use the codes I've explained in this solution
Jun 05, 2011 | Brother MFC-260C All-In-One InkJet Printer
I have a datacard SP35 printer. I recently changed the ribbon and cleaned the machine. Now the cards are printing however they are only prining all yellow, all pink, all blue, black only, or half pink...
I'm having a similar problem, except some of them randomly print correctly too. Let me know what you find out. Thanks, Glenn greiner@unionchapel.com
Apr 15, 2011 | Datacard SP35 Printer
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
My rear sound jacks are blue, green and pink...Im not sure where to plug the three speaker jacks in, as theyre not marked in any way. The speakers seem to be working, except for playing videos etc on the...
what do you mean by your rear sound jack? is that the 3 jacks that you use to connect to your computer ? it depend on if you have 5.1 system or 2.1 system but normally you can plug it in this order : green , yellow , black . The pink normally is for Mic port but if you don't have it then insteed 1 of those 3 colors you replace it with the pink. And again you have to have a software on your computer which is usually come with your computer when you buy it. You'll have to manually configue those port in the software on your computer to get it to work. Good luck and keep me updated.
Oct 22, 2009 | Logitech X-530 Computer Speakers
Canon PIXMA iP 3000: Suddenly, everything prints hot pink
It sounds like the cyan and yellow cartridges are empty. Try new cartridges.
Dec 09, 2008 | Office Equipment & Supplies
Printer S400 won't print out blue and pink ink
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Nov 25, 2008 | Canon S400 InkJet Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
1988 mark 7 color code for sound system
1986-89 Lincoln Mark VII Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) Pink/Blue Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Blue/Orange Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
Aug 17, 2008 | 1988 Lincoln Mark VII
I Have a Brother MFC-640CW all-in-one Inkjet Printer. I changed the ink cartridges and I can get them all working except the yellow, when I do a Test print all the other colors come out perfect except for...
press menu then start bk copy then fourtimes arrow-up quickly after another. machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-bk-copy).
Machine will do some refreshing of ink and some special cleaning.
When finished press 7-6-3 start-bk copy
machine will do a power purge.
leave maintenance mode by pressing 9-9.
do run a test print.
DO USE ORIGINAL BROTHER INK or skyhorse generic ink only due to the fact that other generic ink will defenetly do damage to the printer!
Apr 23, 2008 | Office Equipment & Supplies
Canon i9100 InkJet Photo Printer Logo
233 people viewed this question
old marine
old marine
