Repair manual for polaris 2002 550 fan cooled motor
Fan motor not working unless you hook direct power to it
that sounds like the fan relay is bad. if you call your local dealer and ask for maintenance they should be able to offer a little more insight
Jul 14, 2012 | Polaris ATV
Polaris 700
This sounds like the thermal sensor on the head/block is faulty or in some cases the wires have shorted to the chassis somewhere causing the fan relay to stay on, clould be a faulty relay also.
Nov 25, 2011 | Polaris ATV
Over heating. Cannot find solution in manual.
Is your atv air or water cooled if water cooled is the fan working and radiator clear of mud and horizantal ribs inflat radiator flat. If swollen it will overheat also.
Aug 24, 2011 | Polaris ATV
My cooling fan is not comimg on before the high temp light .in fact the is not coming on at all where should i start? Is there a relay for the fan?
unplug and test the leads with a 12v battery and regular copper wire always test the motor first before going into the electrical relays and sensors
Feb 09, 2011 | Polaris ATV
Just had a piston seize in an 02 550 polaris super sport any ideas
That 550 fan is not a good motor from Polaris. Many engine failures from what should be a very simple and straightforwad fan cooled 550.
Jan 03, 2010 | Polaris New Genuine Polaris Snowmobile...
2006 polaris sportman 500 HO overheating problem HELP!!!!!!
Check that the electric fan motor comes on ,and check the radiator for mud and debris u may also need new oil and filter change,All of these things could make it run hot 1 more thing roll it in neutral 2 make sure breaks arent hanging up.
Dec 18, 2009 | Polaris ATV
Cooling fan polaris 500
thermostat switch has been by-passed, when machine gets up to temp, the switch sends power to the fan, when the switch goes bad the machine will overheat due to the fan not kicking on. make sure the switch has not been by-passed and wired direct.
Jul 01, 2009 | Interactive Toy Concepts Polaris Sportsman...
POLARIS ATV COOLING PROBLEM
There is a sensor on the lower right hand side of the radiator. It is about $75 to replace.
Apr 21, 2009 | Interactive Toy Concepts Polaris Sportsman...
Computers & Internet Logo
David Payne
David Payne
