FixYa.com
Tags:
Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959KQ2 washing machine (by 3 users)
posted by Ihatecalypso on May 09, 2008
My washer will not drain. I have ran the test cycle and it will run through all of the cycles normally until the drain cycle and I hear a beeping sound and the test cycle quits. I sucked the water out with my shop vac so I could work on it and I also looked at all of the hoses to see that it was not plugged. Could it be the drain pump? Or could it be a solenoid switch of some kind. Is this a common problem?
Thanks
FULL TO HERE WITH CALYPSO!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by BRANDOMCQN, posted on Jun 29, 2008
I HAVE THE SAME PROBLEM. I HAVE SUCKED OUT ALL THE WATER WITH THE SHOP VAC AND TRY TO RUN IT AGAIN IT WORK UNTILL THE TIME TO DRAIN IT ONLY MAKES THE LOUD BUZZING NOISE AND WILL NOT DRAIN. WHAT IS WRONG WITH THIS THING?
Comment by Guest, posted on May 18, 2008
washer makes buzzing noise and does not drain
Best Solution
posted on May 13, 2008
Thanks for Trying (70)
tech17
Rank:Guru Guru
Rating: 88%, 933 votes
could be the lid switch or the lids not closed during drain could be something in the pump e mail me at b4829@yahoo.com and ill help
Rating Locked! (?) Ihatecalypso has rated this solution as Thanks for Trying
Can you Help with these Washing Machines problems?
The washer wont fill up with...
The washer starts washing... Answer This...
calypso problem
ever get this peroblem fixed?... Answer This...
Problem with Calypso
Did you ever get a solution to... Answer This...
Calypso displaying SL or5L...
I'm having the same problem you... Answer This...
Tangles Clothes, cannot adjust...
If there is a class action... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
