Question about Epson Stylus CX4600 All-In-One InkJet Printer
Epson CX4600 inks
Are Epson CX4600 & CX6400 printer ink cartiridges compatable?
  • jhmoran May 20, 2008
    what about the CX 8400,are its ink cartridges compatible with the cx4600?
Yes, they use the same series ink set.
Posted on May 10, 2008
I put new ink cartridge and is not printing
clean cartridge if you are not active print docoments then change printer head
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
I was changing an ink cartridge on my epson cx6400 and it stopped at the chearge step. Now all that happens is an 'error mesage and nothing works. I have rebooterd the computer and the printer. Thanks
have you tried installing and reinstalling your ink cartridges?, if so their might have been a physical defect on the ink cartridge itself, this may occur if the inks you installed are 3rd party ink cartridges where the handling is not that good
Oct 15, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Won't rege ink
how to reset ink cartridge for epson stylus cx6400 I have 2 sets of cartridges half full of ink and it will not print it just keeps saying out of magenta
May 16, 2009 | Epson Stylus CX6400 All-In-One InkJet...
try doing 4 head cleans and then leave the printer powered up over night. Don't print or anything else after the head cleans until the morning then do one more head clean (this soaks the print head in ink overnight and then the final head clean should clear any obstruction. If the printer still refuses to print in colour, you could try replacing the cartridges anyway as they can be faulty. The only problem is thaty sometimes it's cheaper to buy a new priner. (how silly is that!) By the way, are you using compats or epson original ink carts?
Nov 03, 2008 | Epson Stylus CX6400 All-In-One InkJet...
How do i change the ink cartridge on my epson cx6400?
I am assuming that you already have a replacement ink cartridge.
  • Make sure the printer is on.
  • If the LCD screen says that your ink cartridge is empty than
you can simply press the Color button (the button looks sorta like a diamond with a line in the middle of it).
  • If you wanna change the ink cartridge but the printer does not say that it is empty then
press the setup button, then press the top left button until Replace ink is displayed. Finally, press the Color button.
  • Lift up the scanner section
  • Wait for ink cartridge holder to move to replacement position then open its cover.
  • Identify which cartridge you want to replace. Press in the tab to release the cartridge, then lift straight out.
  • Before unwrapping the new cartridge, shake it gently four times. Then remove from wrapper.
  • Lower new cartridge into holder, press down firmly until clicks.
  • Close cartridge cover
  • Carefully lower the scanner section and press it down until it clicks
These instructions were found in http://files.support.epson.com/pdf/cx64__/cx64__pg.pdf on pg 12.
Oct 12, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Printer won't print
epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
Sep 07, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson cx6400 ink problem
The ink nozzle may be clogged. You may be using refill ink not from the original epson ink. Try cleaning the nozzle assembly or the printer may not be usable.
Feb 09, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Paper comes out blank
epson cx4600 prints blank paper replaced ink cartages .same problem
Dec 02, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
