Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
When grinding coffee, the process does not stop to allow the water to pour through the coffee, but it continues and then discharges the pellet of unused coffee into the dredge drawer. About every fifth grind, I am losing precious beans. Sent 3 times to tech, no luck
    President:
  • 1,618 Answers
Sounds like the grind is too fine or the brew unit screen and discharge tube is being obstructed.
Posted on Sep 01, 2010
Drips both inside and outside pot. I've ckg for clogs. Nothing clogging
Based on what you wrote, it sounds like your ground coffee basket is overflowing. This happens with my coffee maker if I grind the coffee too fine, or the coffee is very fresh and is off gassing nitrogen.
I shake the basket back and forth rapidly, and often stop the drip to allow the grounds to soak up water for a minute before allowing to go bak to brewing.
I hope I guessed your problem, if so, grind your coffee a bit more course or do as I do, leave ti the way i like it and allow the grounds to soak up some water before continuing with a full brew cycle.
Mar 31, 2016 | Coffee Makers & Espresso Machines
No coffee will come out
Maybe the coffee is down, around the waste container. In this case the grinder must be opened probably the cofee funnel is jammed or is not in his place to direct the grinded coffee.
Jul 29, 2014 | Saeco Odea Giro Plus Coffee Maker
Water tank is full, water gets hot but no water comes up through coffee grinds, using as pour over, not connected to water line.
Remove the sprayhead and check that for blockage. Pour water into the reservoir with the sprayhead removed to see if it flows. If water flows then the problem is the sprayhead. If no water then it is the brew tube and you need a deliming spring to clear out debris. If the only time water does not get through grinds thne it is possible the grinds are too fine.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
It shoots too much water coffee come out watery
try adding more coffee to the filter, or making the grind FINER or both
Mar 08, 2011 | Coffee Makers & Espresso Machines
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
Problem with tamping
Try adjusting the grind to a finer setting also the amount of coffee can be adjusted with the lever in the grinder chamber.
May 06, 2009 | Gaggia Syncrony Compact Coffee...
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Does not brew a full pot anymore.
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process
Sep 01, 2007 | Cuisinart DGB-600 Coffee Maker
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
91 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
