Windowa FAILD to start. a recent hardware or software change might be the cause.
5 Suggested Answers
anasourabh
  • 202 Answers
SOURCE: windows error recovery
you repair ur windows through OS bootable cd, & thn chek it.
Posted on Nov 18, 2009
paul7of9
  • 1189 Answers
SOURCE: Windows failed to start, says
Hello kizzy_t, when a change has been made to the Operating System, Registry... The best thing to do [First] is a "System Restore," if Start Repair didn't 'Fix' the problem; lets try the [System Restore]. The computer will be 'configured' back, to a previous time when the computer was working, or before the change was made. there are two [2] ways of doing this, if you remember the exact "Day & Time" of the change, you can paul7of9_8.jpg 'create' a Restore Point from that day; or the "Restore Point" will be listed for your choosing. It will be safer to go back as far as the "restore points" go.Follow these instructions carefully, and you will have no problem at all. The first thing you want to do is click on the "Start Button,"paul7of9_9.jpg from the Desktop. Next, click on "All Programs," scroll to find "Accessories," next select the "System Tools paul7of9_11.jpg." You will see in the next window that open, "System Restore;" now this is very important, "Once you click on the System Restore "shortcut" it will start to look for the last known time of a change in your computer, ie; "Hardware or Software." paul7of9_12.jpg The System restore can take as long as a 1/2 an hour to run, so be patient if you want it to work. "Do not try to do any type of work, don't even touch the keyboard for any reason, just let it run!" Once the System Restore finds the correct "Date and Time"of the event; choose the Date closest to the time of the occurrence. paul7of9_13.jpg Now once again, there will be a message telling you not to do anything with the computer, and please don't. The System Restore will "run" for a while, so once again be patient. The computer will then "Shutdown and Restart," Lo-gin if you have to? But! Do not touch the Keyboard once the Desktop window open, because System Restore is still running. Wait! Until there is a message letting you know the 'Restore' of your System was successful! Take your time, I hope all goes well, please let me know by giving a "Helpful Rating" Thanks for using Fix'Ya, paul7of9
Posted on Dec 10, 2010
SOURCE: windows failed to start. a recent hardware or
Uninstall Internet explorer 8 and any .net upgrade which is rescent. Try it now and use internet explorer 7 if it is working ok with downgradeor better goto firefox and download firefox.
Other possibility is RAM has failed, if there are two sticks try booting with one stick in theA slot and other removed, alternate the ram sticks to test. If only one ram stick try a similar ram type pc or laptop for ram test, a friend?
Posted on Jan 25, 2011
  • 668 Answers
SOURCE: status 0xc000000f Window failed to start
You are facing this problem because of some software update which you might of done in recent times. So the boot loader is failing with error code 0xc000000f.
Download the Repair for boot loader from the link below:
http://neosmart.net/dl.php?id=1
Run the software it will rectify any errors caused due to any software update.
This will solve your problem.
Hope this helps.
Shane
Posted on Mar 05, 2011
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped responding, restarted unexpectedly, or...
did you recently install a new hardware ?
did you recently install a new software?
if you answered yes to any of these questions above you need remove it.
therefore if you installed a new hardware safely shut down and remove cables and remove hardware.( if it is hardware the hardware is not compatible with windows)
if it a software boot in safe mood then uninstall software. ( to boot in safe mood, press F8 while computer in turned on )
Sep 27, 2010 | NEC VALUESTAR T (VT900/8D) PC Desktop
My computer won't open windows.
Start the system with safe mode and uninstalled the recent hardware drivers may solve your problem.
Revert back for more assistance.
Jan 26, 2010 | Dell Inspiron 1501 Notebook
I start my computer but it wont btake me to my windowa it takes me to restart window normal or on safe mode what do i do
hi click restart on normal mode then wait for it to load up properly then shut it down, wait for it to shut down, then switch it back on if it then comes up with this message you either have a problem with windows software or maybe problem with hardware on your computer
Jan 20, 2010 | E-Machines eMachines Desktop PC
Windows failed to start.a recent hardware or software change migh
sounds like a driver issue. Boot to safe mode and do a system restore..you may also get lucky by booting into "last known good configuration" good luck!
Jun 03, 2009 | Microsoft Windows? Vista Home Premium...
Computer starts but do not start with xp
You should try starting in safemode, if no menu at start, just press F8 after the bios.
perhaps after a restart in safe mode it should have fixed itself, if you add some hardware try to remove it to try,
Nov 27, 2008 | Microsoft Windows XP Professional
Windows failed to start a recent hardware or software change might be the cause
did you try the safe mode in XP?
when you start the pc, start hitting F8 until the pc prompts the safe mode , in the safe mode there are the minimum of drivers available , so you can see what is causing it often an device driver or a graphics card , you have to work around and check what you have recently changed if this doesnt help try installing xp over the existing version , thus repairing bad files.
when this doesn't help there is only one option, format he c:\drive (but make BACKUPS first ..) and start all over again.
May 01, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
