Question about Compaq CQ60-215DX Notebook
When I plug my Compaq computer in, the charger does not charge the computer. The light does not come on. It is running out of power. Is the charger the problem?
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 08, 2010
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
I Have A Compaq Computer But Got Some Reason It Cannot Be Charged.
Ok, your problem is not very well explained, I dont know if you are techy or nooby, also do not mention how old is the equipment. options:
1- Defective battery pack, HP has recalled a few battery pack models for them being defective, check with HP's website to see if yours has been recalled.
2- Defective or not working charger, HP and compaq chargers do not have indicator light unfortunately, so the only way to make sure is by testing the lead with a multimeter.
3- Broken cables within insulation, either power outlet to charger, or charger lead itself broken internally from being stepped on or run over by furniture. test them both.
4- Worse case scenario, if your charging light goes off and on every few minutes, then your power board may be going out or defective, battery not taking charge (dead), possible issue with mother board going bad.
Hope this helps a bit...
Aug 19, 2011 | Compaq Presario CQ35 Laptop Charger...
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Feb 17, 2011 | HP Original HP COMPAQ 6510b 6515b 6710b AC...
The female plug in my Compaq Presario (for AC adapter) is broken from the motherboard. Computer still runs, since the battery is about 90% charged. Cab this battery (it has 5 female terminals) be...
i cannot think of a commercial product designed for this. I believe that you either may need to send it in for repairs, or if the pin inside the female end is bent, try bending it back. BE CAREFUL.
Feb 09, 2011 | Compaq Presario 1245 Laptop Charger...
Hello, I am having problems with my Compaq nx6110 laptop not charging. It is not the battery, as I replaced it at the end of December. The problem seems to be that the charge isn't reaching the battery,...
If you remove the battery, does the AC Adapter power the computer? Does the laptop have a barrel type power connector? I have replaced several power connectors for broken center pin. Does wiggling the power connector affect the charging light?
Mar 20, 2010 | HP Compaq nx6110 Notebook
Presario f700 no fan/lights = nothing at all. The charger works
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
Charging, but no power compaq precario
Hello, Did you twist any of the wires/cable on your charger? Can be a problem on the plug, try, very gently, to turn it, if round that is, and see if theres is a contact in between. Regards.
Jun 11, 2009 | Compaq Presario Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Compaq CQ60-215DX Notebook Logo
176 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
