The catch has broken,door wont shut. - Washing Machines
  • Anonymous Feb 20, 2009
    I had to replace the door handle on my washing machine. The door closes but will not "lock"
    Genius:
  • 1,073 Answers
What is the model number and post back
Posted on May 09, 2008
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
Car Door Won't Close or Stay Shut - JamesMaurer.com
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Jan 16, 2016 | Cars & Trucks
92 Honda accord drivers side door won't open. And
IF DOOR WONT OPEN FROM INSIDE THEN IF YOU LIVE UP NORTH RUST IS PROBLEM.....TAKE A FUNNEL POUR BRAKE FLUID WHERE THE LATCH IS....WAIT 1-2 DAYS AND DOOR WILL OPEN.....SHORT TERM FIX
May 23, 2012 | 1992 Honda Accord
Drivers door wont open
If it were me , I'd remove the inside door panel and take it from there. It may be that you can pry open the lock mechanism with a screw driver or a similar tool, allowing you to open the door - which obviously you must do. Even that, though, will not solve the cause of your problem. You may wind up at the dealer.
Aug 19, 2017 | 1986 Ford Tempo
Its cold and the door was frozen stuck. But after unlocking it, I pried it open and when I got in the drivers seat to close the door. The latch is stuck in the down position and the door wont close or...
spray the latch catch with oil or silicone to loosen the latch mechanism than stick something [a screwdriver/ pen ] that u can use to push the catch upward to open push on catch while lifting handle if catch falls back either latch spring still frozen or latch spring broken and needs replacement
Jan 11, 2011 | GMC Yukon XL Cars & Trucks
I have a Kenmore 500 that shuts off if the load touches the door from the inside or wont start unless I press the door in again after its shut. I'm assuming there is a safety switch the door touches to let...
sounds like the door catch is loose,this is what holds the door shut,when the clothes are spinning they hit the door opening it enough to reset the door switch,there's a metal or plastic tab that goes into the catch,easy to install and part is cheap money
Oct 13, 2010 | Kenmore 500 6952 Dryer
I have a 2000 windstar...the left sliding door
The door is not catching to lock the door shut. Find where it is not catching and see if theres a blockage or if something is broken.
Oct 17, 2009 | 2000 Ford Windstar
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Frigidaire clothes washer model #FWT445GES1. The door wont stay shut, it pops open. The unit wont turn on even when I hold the door shut
I was having this problem. I thought the door catch was damaged but looked it up online and saw that it was intact. I was just about to call the repairman when I took another look and found that the rubber seal around the door was not properly seated. Duh! Almost cost me $100+ and lots of humiliation.
Jun 22, 2008 | Frigidaire Washing Machines
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
