Question about JVC GR-DVL120 Mini DV Camcorder
The screen gives me E04 or E03 saying eject tape and reinsert. I have used the head cleaner and still nothing works keep getting those error codes to show and not let me use the cam.
    Genius:
  • 1,812 Answers
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
3 Suggested Answers
kala
  • 156 Answers
SOURCE: E04 Safeguard mode due to Dirt head
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Posted on Jan 08, 2008
welcomejee
  • 10594 Answers
SOURCE: JVC GR-DV3000. Goes to
If camcorder accepts normal MiniDV tape without any problem and you can record or playback it correctly then please try another brand video head cleaning tape as existing head cleaning tape might be not good that is why camcorder rejects it.
Hope this will help.
Thanks.
Posted on Mar 30, 2011
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
E03 eject and reinsert tape
Because of the black rubber part you have that problem so now you need to find one and insert on the bottom part of you tape deck for your camera to work.
Feb 11, 2014 | JVC GR-D73E Mini DV Digital Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
E04 Error Can't watch or play
Hi there, please check this link: http://www.planetdvd.net/board/index.php/m/131342/0/#msg_131342 Best regards, Arpi
Jun 08, 2007 | JVC Cybercam GR-DVL820 Mini DV Digital...
Video Cameras Logo
118 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
