Question about DeLonghi DFH132 SafeHeat Ceramic Compact Heater
Why does my delonghi dfh132 heater keep switching itself off after about 2 mins on the hottest setting. this is really annoying and doesn't heat the room up, also i have to switch it off by the plug for at least 5 mins for it to start working again?
  • DeLonghi Master
  • 19,396 Answers
Clean the unit from lint that can cause overheating, if that does not help, then replace the thermostat that is causing the problem.
Posted on Sep 01, 2010
How do I get the heating element out of a DeLonghi Electric Oil heater?
many times the sealant they use has to be heated with a torch to remove the element . and if not done properly all the oil in the heater makes a really big mess .
Aug 15, 2015 | DeLonghi Heating & Cooling
Dfh132 manual
You may download the manual here.
Dec 29, 2011 | DeLonghi Heating & Cooling
The heater switches off after 2 minutes on all settings
my delonghi heater keeps switching off - really annoying. Seems to come back on again soon after, but Id rather it just stay on! Any ideas?
Aug 30, 2011 | DeLonghi Retro Fan Heater
We have a new OFC2400TIF heater. We have set a program which worked for a day. Now the heater will not work on either manual or auto. The display lights are all on, the screen indicates that the heater is...
The heater may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the heater from the wall outlet. Wait 12 - 15 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and set the controls as you normally would. Hopefully, that 12 - 15 minute timeout allowed the heater to reset itself. If this continues to occur, contact Dimplex Technical Service at
888-346-7539.
Hope this helps you to further troubleshoot and solve the problem.
Apr 24, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
How do you use the dial and what is it for
This heater has both a dial and a wattage selector. The dial is a thermostat, so it will turn the heater on and off as the temperature gets warmer and colder. Just like the thermostat on the wall in a house. The wattage selector switches let you pick how much heat goes in when the thermostat (the dial) tells the heater to turn on.
If you set the wattage at a higher level, the heater will use more power at once, but will turn on and off fewer times to keep the temperature determined by the dial setting.
If you set the wattage to a lower level, the heater will use less power at once, but will turn on more often and still use about the same amount of electricity.
So the dial really lets you pick how warm you want it to be in the room, and the wattage switches let you pick how often it turns on and gets hot. So this dial really determines how hot your room will be.
Feb 11, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
I have a delonghi fan assisted Convector heater P/N HCA530FTS.\r\nI switch it on and it heats for about 10 minutes then switches itself off. What is the problem.
I would love to assist you fix this problem quickly!
Please respond by pressing REPLY OR COMMENT
do you have a copy of your users manual or do you require a copy before we start?
Bruce
Jan 13, 2011 | DeLonghi Smile Plus Portable Convection...
My heater fell over on its side for about 20 seconds and niow won't heat. Is there a resent switch? Thanks
your tilt safety switch went off.. stand back up and keep unplugged, for about a min..then try it, or until it cools down
Dec 18, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
Audiosonic KMCTH68 Keeps turning itself off after 2 mins
CHEAP TV VIDEO REPAIRS
Can't be 100% sure but the most likely cause of the problem is bad solder connections in the switch mode power supply or on the vertical output IC, or anywhere on the main or picture tube circuit boards, due to age and switching on and off TV's develop bad solder connections when cold the connection is made and when it warms up due to heat expansion the connection breaks, you will need to be handy with a soldering iron, and discharge all power supplies with something like a 100 Watt globe before soldering or you may blow things up and do really serious damage, and be warned TV 's have very high voltages 360 volts DC in the SMPS primary and over 20,000 volts to the picture tube, so be careful.
Feb 03, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Squealing Noise coming from DeLonghi TRD0715T Oil Filled Heater
does the noise occur when its doing its purge cycle? I mean as soon as you turn it on and set your temperature?
Jan 24, 2008 | Rinnai Toyostove Direct Vent Heater:...
DeLonghi DFH132 SafeHeat Ceramic Compact Heater Logo
236 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
