Question about Intel BOXD848PMBL Motherboard
I have a Intel d33025 and i don't get any post or video it starts up with full 12 volts, fans turn at high speed i checked my video card it works on another computer my ram is good and i just got a brand new psu i have no idea i just bought it new from my local computer shop it ran great for about a week then gave out now i get no picture im afraid its my board but Intel wont warranty it was a board sold to a distributor that mods them then sales them to another company and my local shop sucks cause they failed to tell me as i left that they have to install it for full warranty so i have no clue. any help would be great
Hanto
  • 226 Answers
SOURCE: Latest Bios For The E210882
You really should contact Emachine support. I looked for your model # 5250 among all their various model ' series ' with no luck on my end. I also thoroughly investigated the Intel website for your motherboard model # and that doesn't show up either at least not as written by you. I did find on the Japanese Intel website a model that was very similar tho. It is written as D915GAV, not GVA and the website for reference is very hard to read by most West Europeans and Americans. So my strongest recommendation is to go with the first link to Emachine support. I'm sure they can be of some help to you.
Posted on Aug 30, 2008
raminda_6
  • 4 Answers
SOURCE: Intel D945GTP monitor going into standby, cpu fan runnning full blast
first Turn off your pc & allow it to cool down & try after about 30 or 40 minutes. If you get same result remove your AC plug, VGA card, Other Expansion Cards & CMOS Battery(RAM also) After 20 or 30 minutes fix your memory, CMOS battery & change cmos jumper to recovery position & power on your PC if your pc is giving any display there will be a mesage for clear all passwords & settings select that option & turn off your pc. after taht fix your all expansion card one by one.
If your problem is same remove RAM & switch on pc, If you cant hear any beep sound you must check your powersupply & mother board get assist from hardware technician or go to your hardware vendor because there will be a warranty for your motherboard model.
Posted on Oct 28, 2008
jonniewalker
  • 1029 Answers
SOURCE: HOW TO FIND RAM CAPACITY OF INTEL D102GGC2
Intel D102GGC2 Motherboard Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
Maximum Memory Capacity: 2048MB
* Currently Installed Memory: 512mb Number of Banks: 2
* Dual Channel Support: Yes
* CPU Manufacturer: GenuineIntel
* Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Your MotherBoard Supports up to 2GB of memory.
You have 512mb, you can add 512mb to the empty slot.
, however,It's a good idea to keep them the same if you can.
You can install memory that is: DDR2 PC2-5300 (PC2-5300 is 667Mhz) you can use 1gb memory in each module for best performance and matching pairs since your motherborad supports dual channel.you can use sound card and SATA hard disk for higher disk support
Posted on Mar 15, 2009
DickCanFixIt
  • 948 Answers
SOURCE: Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
Posted on Jun 07, 2009
  • 67 Answers
SOURCE: Intel D945GCLF - No post, No video Signal
Sounds like your wiring isnt right on the on off power. Make sure your power supply can handle this MotherboardAdapter cables are available that allow the incorrect use of older ATX or SFX power supplies in place of an ATX12V or SFX12V power supply. Intel does not recommend the use of these cables. These cables convert a standard 1x4 peripheral connector to the ATX12V 2x2 connector. An ATX12V or SFX12V with the 2x2 connector is required for all Pentium® 4 processor based Intel® Desktop Boards. Using the 1x4 converter cables can lead to system component or power supply damage and/or boot failures. The ATX12V and SFX12V power supply design guides (http://www.formfactors.org/)* recommend a minimum of 8A at 12Volts to properly power any Pentium 4 processor based Intel® Desktop Board. Standard ATX and SFX power supplies typically provide approximately 5A of current, which is not capable of reliably powering the Pentium 4 processor based Intel® Desktop Board. And I think the motherboards going to look for a formatted hard drive wired to the motherboard It wont boot off that USB stick.
Posted on Sep 22, 2009
Why does my a/c blower only work on high speed. switch works and resistor good and get power through it.
there is no resistor for high speed fan as it is full 12 volts
the slower speeds are resistor controlled
it should have a resistor pack in the blower housing ( air low to keep the resistors cool)
Jul 28, 2015 | 1970 Oldsmobile Cutlass
WHAT POWER SUPLY IS BEST FOR THE INTELL MOTHERBOARD D33025
If you are using this motherboard with 2 sticks of memory, 1 or 2 hard drives, and the built-in/onboard Intel video chip then this high quality power supply will do very well for you: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151117
If you have a plug-in PCI-e video/graphics card which requires its own 6+2-pin power cable then this power supply will provide high quality and the extra power needed for the graphics card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151119
Nov 04, 2014 | Intel Computers & Internet
No video output. fan speed fast
sounds like a faulty GPU . your graphic chip or card could be burned out which explains the no display and high speed fan.it can also be it cant boot to BIOS.
Nov 11, 2013 | Intel Corporation Network Servers...
Computer turns on, but screen says no signal
Computers send out a video signal.
If the monitor isn't receiving a video signal, you get No Signal on the monitor.
First thing to check is the monitor cable. Cable is used on another working computer to verify, or known working computer's monitor cable, is used in place of it.
I believe we can skip that.
Why?
eMachines are budget computers. Designed to save the consumer money, and give the consumer a decent computer.
Problem is low cost of computer, is due to certain hardware components inside the computer, are of low quality.
The Power Supply being one.
Dirty computer inside, also leads to early Power Supply demise.
You can;
1) Test the Power Supply with a multimeter. If you do not have access to one, economical models sell for around $5 to $12.
You will be testing three main voltages;
3.3 Volts, 5 Volts, and 12 Volts. All are DC Voltage.
In comparison two D cell flashlight batteries store 3 Volts DC.
[ Power Supply's are converters. They convert the dangerous high AC voltage (100 to 240. Depends on what country you're in), to the above low DC Voltages ]
Or do you have a KNOWN to be good, Compatible power supply; you can borrow from a working computer?
(I posted this one time, and the person posted back they had borrowed a Power Supply, from their aunt. Computer sat in the garage unused. When finished they returned the Power Supply. Put it back in the computer. Then went, and bought a new one )
Before performing the above, would like you to try this;
Unplug the computer from power. Press, and hold the Power On button in, for 10 seconds. Let go.
Do this same procedure two more times.
Continue also, until the Power On light doesn't briefly flash anymore.
Now plug the computer back into power. WAIT 1 minute.
Turn the computer on. The processor fan, computer case fan/s, and Power Supply fan; should race, (High idle speed), for a few seconds; then slow down. Let's see.
For additional questions please post in a Comment.
Regards,
joecoolvette
Also post the model number of the eMachines. Some examples, T1090, W3653, etc.
Nov 19, 2012 | E-Machines eMachines Desktop PC
Asus P5NT motherboard - will not boot to bios
The voltage output onto the three main rails as you put it is 12 volts and 5 volts. As you say that there is no beeping, you must be getting power lights and fan spin up. This would indicate a failed graphics card. I may am only going on the information you have supplied. Although if there is no lights or fans it may be a failed psu. You also don't identify your PSU. if you have the one that came with the tower, it isn't surprising.
Sep 05, 2012 | ASUS P5NT Deluxe Motherboard and Intel...
I replaced the heater blower resistor, and the fan is still missing the same speed?
The blower motor is ground side controlled through the switch first and then through the blower resistor. It is entirely possible for the resistor to be fine and the switch is actually your problem.
I need to know what speed is not working and if you have a test light or a volt meter? I will then be able to get you some detailed instructions on what to check to find the true source of you problem.
If you don't have a test light or a voltmeter than you next best possible fix is replacing the fan speed switch.
Sep 29, 2011 | 2006 Ford Escape
I have upgraded my bios of intel D945 DCR and now i have the cpu fan noise problem, when i open a video site like youtube the fan sound increase. Also this motherboard has the sound card problem which is...
Clean the fans. when a fan is rotating it impacts on dust particles at high speed this causes build up and an imballance which causes airflow disruption (noise). As long as you can get sound out of it I don't see the problem, Most stand alone cards give a better sound quality than inbuilt audio chips anyway. Also, they give more control over the sound output.
Aug 20, 2010 | Intel D945GCZ Motherboard
Heater & cooling fan only works on high.Power locks don't work.
there is a resistor for the heating and cooling fan speed. this controls the amount of voltage to your fan, which controls the speed. usually when the fan only works on high it will bypass the resistor and use the full 12 volts for the high setting. your power locks might be part of this circuit. i would check the resistor first then check the locks. usually the resistor is behind the high low switch
Mar 26, 2010 | 2000 Pontiac Montana
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
Dodge Ram 1500, air will blow when switch in high position.
Check the blower resistor for burned or damaged coils.
Jun 16, 2009 | 2007 Dodge Ram Truck
Intel BOXD848PMBL Motherboard Logo
418 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
