Moniter shuts off when i connect modem to it - Computers & Internet
  • 95 Answers
Try to update the Modem driver at manufacturers website. also check the operating system of your downloaded driver.
Posted on Sep 01, 2010
I WANT TO USE MY DESKTOP TO PLAY FILMS ON MY TV . DONE THE CONNECTIONS AND GOT THE RIGHT SCREEN WHEN THE COMPUTER STARTED UP THEN IT WENT BLANK SO I CHANGED THE RESERLUTIONS ON A MONITER SCREEN THEN...
What you should try at this point is shut everything down, Unplug your desktop, hook it back up to tour moniter and boot. If you now get a picture, go to your device manger and click on display adaptors. If you have more than one selection. choose your monitor. Let me know if this works.
Mar 11, 2011 | Computers & Internet
Will not connect to internet
Has it worked in the past, and connected to the internet through the same modem? When I had one of these any time the Internet Connection would hickup I'd have to restart everything in the right sequence. As long as your connections are correct, shut down the Linksys router, by removing the power cord, as well as shutting down your modem. Then restart your modem first and wait until it's all set and ready to go. Then restart your Linksys afterwards so it can find the proper IP Address assigned to your modem. It should connect to the Internet, but you always have to restart the modem first while the Linksys is still off. Also make sure the power is disconnected from your Linksys for at least 30 seconds before powering it back up.
Nov 28, 2010 | Linksys Wireless-G WRT54G Router
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
I keep having intermittant internet conection.
ensure that you dont overheat the modem downloading too much, because if you need to shut down the modem for it to work its because it needs to refresh, you can put some ice on the modem to reduce this effect :P
Sep 14, 2009 | Westell Wirespeed LiteLine 6100...
Aoc 2216Vw monitor black outs
try to check with the monitor selftest if the monitor self test passes, the issue is with the video card. to check your video card: try to connect the monitor to integrated port and check out so that we could find if the problem is with the video card.
Jun 10, 2009 | Sony Computers & Internet
Arris cable modem
try shutting of your computer then shutting off the modem, the modems have batteries you might have to remove them theres usally a panel on the bottom, in the back you should have a wire for comcast cable and an ethernet chord telephone too if you have everything. also your modem could be broken, i had the same problem
Jun 06, 2008 | Arris Touchstone 450a (CM450) Modem
Unable to fax out
usually confilcts arrise like this when 2 or more type connections are present on one comp especially if not integrated on same card together.
solution: disable nic reboot pc then send fax should go alright.
though if you have call waiting you should disable it before sending any fax.  try using WINFAX  proven technology.
Oct 13, 2007 | Genica Conexant R6793-11 56K V.92 Data/Fax...
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
The crazy blue box
crazy stuff here.. it might be the display or the harddrive check the pins on the display cable. how old is the PC? and have you added anything to the computer to damage the motherboard? I suggest doing a system recovery it might solve the promblem.
Sep 12, 2006 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
