Question about Actron Digital Multimeter Tester
From where could I obtain a Leviton DMM 830-12504 operator's manual?
Leviton dimmer
Your product is not identified by number given.
Leviton posts manuals online by searching Leviton xxxx .pdf.
There is a CPT 602 lighting console
However no result shows online or at Leviton for a 602 dimmer
Contact Leviton:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37579&minisite=10251
Add a comment and attach photo or video for possible identification
May 27, 2013 | Leviton Electrical Supplies
Where is the location of crankshaft sensor in VW passat,1995,2,8?
OPERATION
The crankshaft position sensor detects gaps in the sensor ring corresponding to TDC of each cylinder. The sensor uses a permanent magnet, core and coil. The changing gap causes the magnetic field near the sensor to change. This in turn varies the voltage signal to the ECM. The ECM uses the signals for ignition timing and fuel synchronization.
TESTING
Audi A4 2.8L
  1. Disconnect the electrical harness connector.
  2. Switch the DMM to its resistance range and connect it between the CKP sensor connector terminals 1 and 2 , using jumper wires from VW 1594 test kit. The DMM should show approximately 1,000 ohms.
  3. If the specified value is not obtained, replace the crankshaft position sensor.
  4. If the specified value is obtained, connect the DMM between terminal 1 and 3 (GND), then between terminals 2 and 3 (GND). The DMM should show infinite ohms (open).
  5. If the specified value is not obtained, replace the crankshaft position sensor.
  6. If the specified value is obtained, check the wiring for continuity or short between crankshaft position sensor and ECM, using a wiring diagram.
  7. Connect a VAG 1598/19 test box to the ECM harness connector.
  8. Check the CKP sensor shielding for continuity by connecting a DMM between terminal 3 and engine ground (GND). The DMM should show a maximum of 1 ohm.
  9. Check the wiring for continuity between the CKP sensor connector terminal 1 and the test box socket A9 , then between the CKP sensor connector terminal 2 and test box socket A10 . There should be a maximum of 1 ohm.
  10. If the specified values are not obtained, check and eliminate any short or open circuits in the wiring.
  11. If the wiring is OK, replace ECM.
Passat 2.8L
  1. Disconnect the harness connector from the crankshaft position sensor.
  2. Switch the DMM to its ohms range.
  3. Connect the DMM to terminals 1 and 2 of CKP sensor harness, using adaptor leads from VW 1594 adaptor kit.
  4. Resistance between terminals 1 and 2 must be 500-700 ohms.
  5. Connect the DMM to terminals 1 and 2 , then 1 and 3 of the CKP sensor harness, using adaptor leads from VW 1594 adaptor kit.
  6. The resistance must be infinite ohms.
REMOVAL & INSTALLATION
  1. Disconnect the electrical connector from the sensor.
  2. Remove the crankshaft sensor retaining bolt and remove the sensor.
  3. Replace the O-ring and lightly lubricate it with clean engine oil.
Installation is reverse of removal.
To remove the sensor:
  • Disconnect the wiring harness.
  • Unbolt the sensor mounting bolt.
If the crankshaft timing sensor or the camshaft reference sensor is removed, follow this procedure when the sensor is replaced:
  • Thoroughly clean the sensor tip and install a new spacer on the sensor tip. New sensors should be supplied with the spacer installed.
Spacer on crankshaft timing sensor and camshaft position sensor.
  • Install the sensor until the spacer lightly touches the sensor ring, and tighten the sensor mounting bolt 105 in.lb.
Look for the sensor on the axis of the crankshaft near either end of the engine.
Good luck on locating this sensor.
Jan 17, 2011 | Volkswagen Passat Cars & Trucks
Need instructions to set my timer. Where can I find these?
You posted under Leviton 6124
If this is not your timer, add a comment.
Also see Leviton timers at:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 manual
http://waterheatertimer.org/images/6124-manual.pdf
Wiring for 6124 timer:
Add a comment if you need help wiring this timer
Nov 30, 2010 | Leviton 24-Hour LCD Programmable Timer,...
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
How can I program my Leviton timer model 6651-I?
Leviton 6651 Manual.
http://waterheatertimer.org/pdf/Leviton-6651-manual.pdf
Timer requires a battery which should be replaced each 12 to 18 months.
Timer replaces single-pole or 3-way switch, and does not need a separate neutral wire.
Timer is for incandescent lights only.
500 Watt capacity
Push the door for manual override to reverse program that is in effect.
The 14 hour timing period is represented by 24 dip switches.
Each dip switch is positioned for ON or OFF.
Click the dip switch right or left
Start at the bottom
For example: ON for 3 hours, OFF for 4 hours, ON again for 3 hours:
Click dip switches 1 thru 3 to ON position, 4 thru 7 to OFF position, 8 thru 10 to ON position
ON position is to the right.
OFF position is to the left.
At the end of the 14 hour program, the timer turns lights OFF until the original start time is reached after 24 hours.
Timer will operate like this while in AUTO mode, until function switch is moved from AUTO to MAN or OFF modes.
Function switch is located at very bottom of timer door.
To activate program (on first day), function switch is set to OFF position for 2 seconds, and then move function switch to AUTO mode, and programming cycle begins.
Nov 11, 2010 | Solar Leviton 6651 Decora Programmable...
Need a manual for a Wavetek DMM, digital multimeter model DM15XL
Here it is:
http://www.tequipment.net/pdf/Wavetek/5XL10XL15XL16XL_Manual_Rev_A.pdf
Nov 15, 2009 | Measuring Tools & Sensors
Actron Digital Multimeter Tester Logo
213 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
