Question about Canon PowerShot A75 Digital Camera
Canon Power Shot S21s screen is black
I am having the same problem mentioned by the others about a black screen and not being able to take any pictures. I have a 256 card in it. You can see the camera settings but no picture. I did not see anyone come up with a solution yet. Help! Please!
  • sherry042 Jan 08, 2009
    black screen and when put on stitch assist i get strange information and the screen size for pictures is smaller with lots of numbers arrows etc.
Press the and hold the display button while placing the camera lens down on a table so that the lens is covered allowing no light to enter then lift it back up. This seemed to reset the light balance.
Posted on Nov 04, 2008
Thank you for the Cannon Customer Service contact info..
The Cannon C.S. Rep. was very friendly and helpful. I will be sending my Cannon A75 to the authorized service center in IL.. Hopefully, Cannon will repair my camera @ no charge (probably a bad CCD Sensor) and return it to me quickly????
Thanks again,
Bikerdoug
Posted on Nov 01, 2008
Canon is not covering the s21s model
Posted on Oct 31, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey birdstrike,
According to the manufacturer there are two options. You can try pressing the display (DISP.) button, and if that doesn't work you are probably going to have to get it serviced by an authorized service center. There is a know problem with the CCD sensor on this camera and other model cameras that causes a malfunction when the camera is exposed to heat or humidity. Canon is covering this repair, and I have included a link below to the instructions on what to do.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 09, 2008
Unable to take pictures
Your camera will need a lens. Contact Canon regarding repairs (it may be covered due to a CCD Imager fault)
Apr 02, 2010 | Canon PowerShot S2 IS Digital Camera
When i insert 4gb memory card into canon power shot s21s, camera is disabled. cannot take pictures
Your new 4GB memory card is the problem. The card would likely be an SDHC card (look on its front cover). Your A540 camera was designed well before the SDHC format came out, and your camera will not recognize it. Your camera can only use standard SD cards (2GB or less). Here's some from Amazon.
Feb 14, 2010 | Canon PowerShot A540 Digital Camera
Canon power shot s21s
if ur pics are also blank as ur viewfinder when u see them on pc then it is a
CCD FAILURE !
dont worry u are eleigible for free repairs it is a manufac fault just see the link and call canon in ur area they will repair it free of charge dont worry if u are out of warranty or ur model is not mentioned on the list just call them everything will be ok PLS RATE ME FIXYA for help
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Apr 09, 2009 | Canon PowerShot S2 IS Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
This is a common problem in older Canon S2 IS cameras, especially ones that have not been regularly used. What happens is that the lens iris gets stuck at a small aperture. Most often you can get function back. Here's how:
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority ("Tv").
Use the four-way button on the back to set the shutter speed to 15 seconds. That's right, 15 seconds.
Press the shutter release. Count to seven, then pop open the battery compartment.
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
Once you have it working again, you should use the camera regularly to keep it from sticking again.
Aug 31, 2008 | Canon PowerShot S2 IS Digital Camera
Black screen
Sounds like you have a bad CCD. You can try contacting Canon to check out your options on how to get this repaired. Unfortunately the S2IS is not on their CCD recall list of cameras.
Mar 06, 2008 | Canon PowerShot S2 IS Digital Camera
PS s21s adapter for TC-DC58B
Yes you need to order the lens adapter/Hood set, available from the the Canon e-Store for $30.
Hope this helps.
Sincerely,
HeavyDLB
Feb 27, 2008 | Canon PowerShot S2 IS Digital Camera
Blackness on camera screen
If it is a recent purchase go back to the retailer. Try the Canon Web site Technical Support team once more, a low cost replacement may be ontainable Broadly speaking digital camera are not repairable The economics don't stack up and there is usually no new spares supply although a repairer may have accumulated stock of bits'n'pieces'n'pieces thatt may suit from other dud camera's and his charges will be high as mentiond
Jun 16, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A75 Digital Camera Logo
250 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
