Question about Sirius Satellite Radio Sirius Sportster SP-R1 Satellite Radio Receiver
Fuse problem I had a fuse to blow in the cigarette adapter and replace it with a similar tube fuse, but I still do not have power to the base station. Help!
  • Anonymous Mar 01, 2009
    my plug in to lighter popped out as did the fuse
    reapplied-didnt work
    reinsert other way still not working
    Problem Solver:
  • 35 Answers
I see that you have your adapter and as far as I can tell with this type of problem you may have look at sending it back just because I think your wiring is faulty on the inside or your base station where your radio would sit...there may not be no contact on your station prongs that a connect to the radio. The docking staion connectors may be faulty and need to be replaced. I would beleive this to be relevent to the problem you just described.
Posted on May 10, 2008
Suzuki vitara 2006 cigarette lighter is not working
When you say cigarette lighter does not work, do you mean the insert part, which heats up to light a cigarette, or do you mean the socket? You can test the socket by plugging in a cell phone charger or similar device to see if there is any electricity. If not, then it would be the fuse. To find the fuse, check the net for a manual, stop by the dealer/parts department and ask where it is, or ask at repair shops in gas stations.
Dec 15, 2013 | Cars & Trucks
Cigarette lighter ans accessour power point not working... it's not the fuse
I had a similar problem I thought it wasn't the fuse because I had only checked one but there are two cigarette fuses. Also you can replace the whole cigarette lighter if it is getting power to it. If it isn't there might be a bad wire leading to it. Get a test light to see if it's getting power through the fuses hole.
Aug 12, 2012 | 2001 Chevrolet Impala
It doesn't power up
There is a small power button at the base of the device. No offense, but are you sure this is still pushed in to the "on" position?
Also, I have the same device, but I did blow my fuse. However, I lost it and cannot remember the number on the fuse. Would you be willing to post the fuse replacement part number for me?
Mar 26, 2012 | Pro Power GOgroove FlexSMART X2 In-Car...
I have a 1999 Buick Century. When I plug my GPS power adapter into the cigarette lighter outlet, I blow the fuse. ---Can you suggest a solution? ---How many amps are in that...
Probably a 15 to 20 amps..If you use the cigarette lighter does it also blow the fuse ,you may have a short in the circuit..It should be able to handle the GPS..Dont increase the fuse size,you can cause bigger problems
Sep 05, 2011 | 1999 Buick Century
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
My garmin nuvi 650 na keeps depleting its battery even though I just fully charge it on the computer. It also does not charge when I plug it in the cigarette lighter in the car. The screen turns dark...
well if you have the factory car charger. There is a fuse inside of it. This is indicated in the manual. But it could also be the cigarette lighter fuse in the car is blown. I would make sure the cigarette outlet has power. If the cigarette lighter has power and you have the factory power cable that has a fuse try this. f the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
let me know how this works by following up with a comment and i can instruct you on where to go from here. Thanks.
Aug 26, 2010 | Computers & Internet
My fuse blows everytime i plug in my sirius radio to cigarette lighter...why?
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
May 12, 2010 | Sirius Satellite Radio Receiver
Fuse to suburban cigarette lighter/power locks keeps blowing.
Unplug cigarette lighter, check circuit, unplug each door individualy at first, Don't forget the back doors, check circuit. Usualy the door wiring is damaged but there may be more then two cigarette lightes depending on the model.
Dec 29, 2009 | 1990 Chevrolet Suburban
Black and decker air station will not turn on
  1. Take off the bottom(6 screws philips2_bing.gif)look for a small glass fuse Marked F1 that is soldered in place.
  2. Cut this fuse out(cut as close to the fuse as possible)
  3. Replace fuse(1.25amp 250Volt) You can find on e-bay search by 1.25 amp) there is a fuse with the wire already attached on it....solder new fuse in place.
  4. If you dont want to wait to order the fust just solder a wire into the fuse area(you will have no surge protection but it may worth the risk because the frequncy this fuse keeps blowing.
Side Note: It may look like the fuse is O.K. but trust me its blown.
There are 2 compessor bellows keep in mind they don't both run at the same time One is for AC the other for DC.
Dec 06, 2009 | Black & Decker ASI300 Air Station Inflator
Blew the fuse in the cigarette adapter
I got replacement fuses at Radio Shack.
Dec 05, 2007 | Lowrance Iway 500c GPS Receiver
Sirius Satellite Radio Sirius Sportster SP-R1 Satellite Radio Receiver Logo
202 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
John
John
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
