Question about Reebok V 680 Treadmill
I have a reebok v4000 and all the light on the console are flashing and not responding to any touch
My Reebok ZR9, screen flashes on and off with constant bleeping sound.
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Apr 26, 2016 | Reebok Exercise & Fitness
Have reebok 8500 ES has been stored turns on but does not respond to console ,it as if they are not speaking to eachother
Maybe check for a reset button around the motor/ belt drive. Manually roll the belt a little to free up motor if it's been sitting awhile.
Sep 03, 2015 | Reebok 8050 ES Treadmill
My Reebok S 9.80 will turn on but when I push any button on the console it just beeps and does not respond. What does that mean?
yes - had to recalibrate it. Plug it in, remove the key, hold down speed + and the stop button on the console, while holding them down replace the key. release the buttons, then press stop once. then press and hold speed + until speed reaches max. unit should run and speed up to max. console should display max speed (s9.80 should read 11.8 to 12.5). It took me a couple of tries to get running but now it is OK. If after several tries the unit does not run then the console will probably need to be replaced ($410) - so get a new treadmill ! If unit does run then it may still beep. Problem is with the IFit card. You can get rid of the beeping by opening the console (unplug the treadmill first) and removing the cable that connects the IFit card to the mother board. Of course the IFit will not work but it will not be beeping at you. good luck
Nov 21, 2010 | Reebok T 980 Treadmill
My compaq presario v4000 does not support windows vista properly and responds very slowly i want to upgrade it to windows 7 but every time it gives an error of your system cannot be upgraded...
your system bios should be upgrade first. Find bios upgrade software from your laptop vendor's website. upgrade bios first then install Win 7.
Oct 13, 2010 | Compaq Presario V4000 Notebook
LIGHTS ON CONTROLLER FLASHES BUT WONT RESPOND
you have to reconnect it. Click the home button on your remote click connection settings, and hit reconnect. Then press 1 and 2.
Mar 10, 2010 | Nintendo Wii Console
Reebok rx3000 treadmill. panel lights up fine. 2 of the 10 speed buttons will not imput and the start button will not start the treadmill. checked the power panel. led lights to voltage light up fine, but...
it is two items in this case. The light on the PWM will light if you force the belt to move. I would start with a lower board replacement. If it works fine then you need a new console. I have seen this when people use the heart touch bars on the treadmill and get a static shock. this can ruin the console.
Apr 18, 2009 | Reebok 8050 ES Treadmill
Reebok V 680 Treadmill Logo
51 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
