Start a dos program instaled on xp
I instaled an old dos accounting program on windows xp.when i try to start it, although it says that accounting utility is starting, instead of entering it reports n error that cannot find something and it terminates. Can anyone give a possible way to fix it?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Microsoft site has the solution for you.
The link for the article is here :
http://support.microsoft.com/kb/324767
It will resolve your problem.
Good Luck.
Live, Love, Laugh.
Posted on May 10, 2008
I use Paradox Version 4.5 on my old Windows XP computer. Now I need a new computer that will have Windows 7. How do I install my Paradox 4.5. I've all ready tried everything that I can think of but no...
I use "DOS Box 0.74". it opens a dos window that you can run paradox in. Its FREE and works great, even in full window mode. Only issue I had was I toggle to DOS occasionally to clean up txt files and DOS Box has limited DOS commands.
Jul 26, 2011 | Borland Paradox 4.5 Full Version for PC
It wont install on windows xp
Trying installing the game in compatibility mode by right clicking on the EXE file on the medium used to start the install for the game and click properties. A window should pop up with a tab called Compatibility. Under compatibility mode click the check box to "Run this program in compatibility mode for:" In the drop down menu click Windows 95. Then try to run the install again.
Mar 16, 2011 | Capstone Software Trump Castle 3 for...
Constructor does not want to run on my windows 7
It's a very old piece of software. If you have windows 7 professional or ultimate you can install virtual XP which will allow you to install older DOS programs.
If you have an extra copy of Windows XP or lower you can install that next to your copy of Windows 7.
Alternatively you can install Oracle Virtual Machine that lets you run a virtual machine inside of yours which could be Windows 98 which would be much better suited for installing that.
Mar 01, 2011 | Acclaim Constructor for Windows, DOS
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Error in ms office
Rename and Reinstall the Vbe6.dll File
NOTE: You need your Office CD-ROM to complete this task.
  1. Quit all currently open programs.
  2. Start an MS-DOS prompt in a window by doing one of the following:
    • Microsoft Windows 95 or Windows 98: Click Start, point to Programs, and then click MS-DOS Prompt.
    • Microsoft Windows Millennium Edition (Me): Click Start, point to Programs, point to Accessories, and then click MS-DOS Prompt.
    • Microsoft Windows NT 4.0: Click Start, point to Programs, and then click Command Prompt.
    • Microsoft Windows 2000 or Microsoft Windows XP: Click Start, point to Programs, point to Accessories, and then click Command Prompt.
  3. To change the directory to the location of the Vbe6.dll file, type one of the following (including the quotation marks), and then press ENTER: CD "C:\Program Files\Common Files\Microsoft Shared\Vba\Vba6"-or- CD progra~1\Common~1\Micros~1\Vba\Vba6NOTE: This is the default directory for the Vbe6.dll file. If you installed Microsoft Office into another drive or directory, you must type its path.
  4. To unregister the Vbe6.dll file, type the following.
    In Windows 95, Windows 98, or Windows Me, type: C:\Windows\System\REGSVR32 /U VBE6.DLLIn Windows NT 4.0, Windows 2000, or Windows XP, type: REGSVR32 /U VBE6.DLL-or- C:\Winnt\System32\REGSVR32 /U VBE6.DLLNOTE: This is the default directory for the Windows System directory. If you installed Windows into another directory, you must type its path.
  5. In the MS-DOS prompt window, rename Vbe.dll to Vbe.old by typing the following and then pressing ENTER: rename vbe6.dll vbe6.old
  6. Quit the MS-DOS prompt window. To do this, do one of the following:
    • Type Exit at the command prompt, and then press ENTER. -or-
    • Click Close (the X in the upper-right corner of the window).
  7. Start Microsoft Word.
  8. On the Tools menu, point to Macro, and then click Macros.
    The Windows Installer detects that the Vbe6.dll file is missing on the system, installs the file from the Office CD, and registers it again.
Mar 23, 2010 | Microsoft Office Professional 2007 Full...
I have it almost installed but before i can play the game my screen changes resloution and magnifies my windows then i get an alert box telling me that the organ trail game cant be installed then it closes...
Ahh i see.... Starting with windows 2000/XP. Windows no longer supports DOS... Im kinda sad about that myself D= but it doesnt end there for you my friend. Organ trail is a great game.
My tip is for you to get a program called DOS box from source forge. Simple google DOS BOX. Install the program and run the program from within dosbox. If you dont know how to run dos box simply drag the EXE you are trying to run into the window. Give it a try and it will work trust me. GL in the game....
Feb 19, 2010 | Computers & Internet
DOS program on Windows XP
Go to the desktop and find the icon for your program. Right Click on it to get the Properties dialog box. Select the compatibility tab, then select the compatible operating system for the programs.
This should get your program working again.
Good Luck
Feb 09, 2010 | Microsoft Windows XP Home Edition
Hi guys, I have a 21'' monitor running on an XP machine that was from a DOS machine. It was used on the DOS machine to run a specific program in a resolution using a little program called tmode that only...
- reboot pc
- while rebooting press F8
- choose safe mode
- choose administrator account
- go to control panel
- switch control panel to classic view
- click System
- click Hardware tab
- click Device Manager
- unistall "Monitor"
- then reboot pc
- wait til pc goes to windows
- windows will automatically install new Display Monitor.
Hope this help
Jul 14, 2009 | Computers & Internet
Im trying to install win xp on a used computer
Are you useing the windows xp cd?
Enter the xp setup when asked "press any key to start from cd.." (press a key here so you get into the blue windows installer)
And follow the steps, do you get problems there?
Jun 05, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
