Question about Dell A920 InkJet Printer
I have a dell A920 ink jet, just bought brand knew ink. Color works fine. Black is having problems. Test page print s fine but win I try to print the the alignment page black is very faint and then when I try to print a Word doc the printer does not sound as if the black ink is engaging! I hope that made since. Please help School starts next week and my senior needs a printer! Thanks
  • floradaluna Sep 01, 2010
    I can print in a very dark brown. How do I do a print head Deep Cleaning? If that does not work how do I take the print head off to soak in hot distilled water? And how would find and take of the ink pin to soak?
  • floradaluna Sep 02, 2010
    Original question:
    Reply from myself with no response:
    I can print in a very dark brown. How do I do a print head Deep Cleaning? If that does not work how do I take the print head off to soak in hot distilled water? And how would find and take off the ink pin to soak?
    Thank you.
  • Dell Master
  • 17,130 Answers
Please remove the printer and uninstall the software in your PC .The reinstall and connect the printer to be detected and installed. Now do a maintenance head cleaning and take a test print.
If there is no change on your printing quality then I think the black you have put into could be a suspect.
The other suspect can be the headd by itself. So try to repeat the head cleaning process till there is some change or the head starts to print better.
Take the printer properties and set the contrast levels.This might make a difference.
If not the head might need a change.
Posted on Sep 02, 2010
  • 857 Answers
More than likely you have a problem with your printhead not your cartridge but no genuine cartridges cause the most problems. It either dries out, clogs up or a piece of jammed paper gets stuck on the printhead.
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.
Clean nozzles.
try another black ink if it is work in it. if no available ink then, try to soak the ink pin onto the lukewarm water for 30 seconds and wipe it out until dry and then insert it back to the ink holder.
Otherwise the printhead requires replacement
Posted on Sep 01, 2010
  • Jayant Jha Sep 03, 2010
    To do a deep cleaning you can use the printer utility software
    or refer your manuel for instructions as it will need an experties to open the printer and preform these steps, do it only if you are comfertable doing it, else contact a tech.
    Guru:
  • 402 Answers
Hi, floradaluna
Could be the nozzles have dried up and won't let any ink out. Soak the nozzle end of the cartridge in a shallow pan of warm (not hot) water for about 10 minutes. Then blot the nozzle end and reinstall. That may take care of it. Otherwise it's probably a bad cartridge.
Dimension E510 with D925 CPU and Vista Home Premium 32 bit
Home Built PC with Q6600 CPU, 8GB RAM, HD4850 Video, Soundblaster Xfi Titanium Fatality - Windows 7 64 bit Professional
Sonar 8.5.3 ( Producer) DAW Software/MAUDIO FastTrack 8R USB Recording Interface, Frontier Tranzport wireless controller and Behringer BCF2000 Control Surface
Thanks,
Ben
My printer has been printing just fine until today. It still "acts" as though it is printing, but a blank page comes out. I have replaces both black and color cartridges and have shut down the...
Have you tried running cleaning the nozzles using the software? Here is a link on how to do it:
http://support.dell.com/support/edocs/systems/A920/a920en1.pdf
just checking that you also removed any "tape" that might have been on the ink cartridges prior to installing them?
Oct 27, 2010 | Dell A920 InkJet Printer
Can't print and when i did got green color
Check the level of your black ink. Double click on your printer icon. This should bring up Dell solution center. Click maintenance and it show the level of your black and color ink. If it appears you have black ink you might try clicking on your menu file, print click on preferences, check print black and white only. If you don't get a printed page. You're for sure out of black ink.
If you get a black printed copy, Double click on your printer icon, click on the maintenance tool to clean and test nozzles.
Jul 01, 2009 | Dell A920 InkJet Printer
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Hoirizontal white lines and poor quality in black and white print on dell a920 inkjet printer
If you are sure your ink cartridge is not empty, it may be worth running the head cleaner a few times then print a test page.
Worth a try for nothing.
Good luck.
Feb 23, 2009 | Dell A920 InkJet Printer
A920 printer will not print in color & the cartridge is OK
is there any more colour ink inside? if there is ink inside you just have to open your printers properties dialog and look for a color option that uses black only. 2. see if the colors are blocked
Feb 07, 2009 | Dell A920 InkJet Printer
I bought a new Dell color ink jet cartridge for my Dell All in One 942 printer and after I replaced it it still showed it as an empty color cartridge. I order it as new directly from dell. I tried to take...
  1. I TRIED HOLDING THE INK JET OVER A POT OF BOILING WATER AND THEN BLOTTED IT WITH A PAPER TOWEL AND PUT IT IN THE PRINTER..CICK ALIGINMENT AND IT WORKED!!!
Jan 18, 2009 | Dell 942 All-In-One InkJet Printer
Printer will not print in color
I have put in brand new color and black and white cartridges. The black works fine on the test pages, but not one bit of color shows. How can I fix it?
Apr 18, 2008 | Dell Inkjet 720 Printer
Flashing Green Light/ Computer can't communicate with printer......
Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
Hope this helps.
Dec 14, 2006 | Dell A920 InkJet Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Unable to print using black printer cartridge
Well, Yeah mine did the same thing!!
And I got soooo fusy! and etc. But yeah okay go to the manul script and look for the ink Number then once you find the ink number go and buy the ink that has the same number of ink as yours!
Then,
Once you get home replace it with the others.
BUY THE BLACK INK! not the TRI-COLOR!
Sep 25, 2006 | Dell A920 InkJet Printer
Dell A920 InkJet Printer Logo
43 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
