Question about GE 24 in. GSD2220Z Built-in Dishwasher
Dishwasher will not start
I have a GE Model GSD 2230Z01WW dishwasher 9 years old just will not start the last few days. Is it the swith , the Latch, or the Mechanical Timer
Please tell me immediately because I and the wife have severe ostoarthritisan da re on Social security and cannot afford a repair peson (My neighbor has agreed to help us if we get the part? which is where you come in the picture.
    President:
  • 1,314 Answers
Hello there im on ss too so i have a soft spot for any one who's trying to live on it first the problem can be any one of the things you mentioned there is no magic bullet that i can just say this is it your problem your neighbor will have to test but i will be happy to assist one of my instructors once told me appliance repair is easy you find out where the power starts you find out where it stops in between those two points is the problem first place to check is the breaker make sure its on that's where it starts then remove the lower kick-plate and check where the power hooks up under the washer from there it goes up to the door latch switches from the door latches it goes out to the timer from the timer it goes to the water valve safety switch then to the water fill valve then to the main motor now even if the timer motor was bad it still should fill when you turn the timer to start some where on the washer is a tech sheet which showers the switches and wiring diagram may be under the bottom kick plate but first check the breaker if its tripped turn reply to be and we will go from there just reply to this post and hold my rating till we fix it ok
Posted on May 09, 2008
When I hit the start button on my GE dishes washer the light in the front is blinking and it will not go on
This sometimes happens when there is a problem with the door latch system or switch. Your door may be closed but the control still thinks it is open. Check the door latch and switch alignment. GE had a problem with the doors dropping slightly about a year ago. the latch looks like a arrow head on top of the door center that pushes into the switch that is mounted on the dishwasher body. If the arrow head is slightly lower than the part on the body you will get the exact problem you are having. GE has hinge shims that they install to raise the door up slightly to fix the problem. Not sure your dishwasher is one of these without a model number.
Feb 28, 2015 | GE Dishwashers
The start light is flashing on my GE dishwasher?
What's the model number? How old is this dishwasher? The new GE dishwashers (less than 3 years old) have a weakness in the door switch/latch assembly, and that would cause the light to flash - it wants you to press Start and close the door, but it's not recognizing that the door is closed.
Feb 10, 2015 | GE Dishwashers
What causes the water to stay running on a ge gsd series dishwasher?
The float is stuck it may need to be replace it is located on the front left side of the dishwasher
Apr 08, 2013 | GE 24 in. GSD1000G Built-in Dishwasher
Suds, overflowing out of dishwasher
Its old get a new one these are not designed to last more than yours did.
May 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Ge dishwasher problem
Soap is not disolving because either your water temp. is too low (adjust at water heater).Or your sprayer arms are clogged up.(remove any particals that can be trapped in the holes on your sprayer) THATS IT !! PLEASE LEAVE A RATING !!!!!
Jun 08, 2008 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 24 in. GSD2220Z Built-in Dishwasher Logo
222 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
