Question about Mitsubishi WS-65807 65" Rear Projection Television
My ws-65807 wont turn on or stay on. I performed the self check and received 2,1 Please advise...
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Unplug set and plug back in and try again, confirm 2,1.
2,1 is XRAY protection, it means something is causing the high voltage the set develops to go too high--creates xray radiation from the tubes.
Let me know what you find. Unplugging will clear the buffer and allow you to confirm if it is 2,1.
If you need advice, I know these sets.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 01, 2010
  • as4494 Nov 06, 2010
    How do you find the problematic component?? I have this very problem in ws-65807.
  • SD Tech
    SD Tech Nov 06, 2010
    post your own question here for free or pay and if want make it attention SD TECH
Turns itself off and then won't stay on
Do the self check.
If you unplugged the set, plug it back, turn it on and allow to fail.
Press both the Menu and Input (input may be labeled device) buttons on the front of the set and Hold both for at least 5 seconds and release both.
Power light will begin to blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of 5 times.
Let me know what error you find and I tell you the meaning and a possible answer.
Dec 21, 2012 | Mitsubishi WS-65807 65" Rear Projection...
I have a mitsubishi ws-65807. I have no picture or sound. It used to work.
try the self check this model has, try to turn set on and when green power light comes on and goes off press and hold both the menu and input buttons on the front of the set at the same time for at least 5 seconds and then release both buttons.
This is a self-check this model has----the power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
The idea here was to narrow down what area the problem is in.
Let me know with a comment here and I will tell you what the error code you found means.
SD TECH
Apr 12, 2011 | Mitsubishi WS-65807 65" Rear Projection...
My ws-65807 wont turn on or stay on. shop vaked the board and looked at the fuse and the fuse looks fine. is there anything else I can do?
do the self check if it comes on for a moment and then the power light goes off.
On the front of the set hold both the MENU and INPUT(also called DEVICE) together for at least five seconds and then release both buttons.
The power light will blink an error code--for example 2 blinks a pause and 2 blinks--it will repeat it several times. 2,2 is the most common error code for this set.
Let me know what you find and I will tell you what it means--it is designed to give a quick idea of what is wrong with the set.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 19, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Our tv comes on and then the picture goes dead
WS-65807 has a self check feature. If the power light comes on and goes out after a few seconds engage the self check:
On the front of the set press and hold BOTH the Menu and Input(or Device) buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should then blink a two digit error code--the most common is 2 blinks, a pause and 2 blinks--this is the most easy to fix. The set will repeat the error code several times.....
Let me know what error code you find and I will tell you what it means and what may be wrong.
If this information has helped you rate this solution as I do this here for FREE.
SD TECH
Nov 29, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Mod#vs60607 tv
Check for wet area on signal PC board = leaky CRT seal.
................T.
Apr 15, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Power wont stay on
Check for coolant leak on signal board = bad CRT.............T.
Feb 28, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Tv does not stay on.
Your most likely having a problem with your power supply. I would say check the capacitors for obvious signs of swelling and all fuses first. Next I would check your low voltage regulators.Have you tried pushing the menu and imput buttons together and holding them for 5 seconds to access the self diagnosis feature? If you cant initiate the self diagnosis feature its probaly the capacitors or Regulators.
Jan 03, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Power on won't stay on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Sep 07, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807
OPTION MENU "MENU 8270" SERVICE MENU "MENU 8257" CONVERGENCE MENU "MENU 8259, 4 FINE, 5 COARSE, 6 MISC." Then you can also check by:This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
May 22, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
