Question about Compaq Presario 700 470024-192 Notebook
I get a request to download updates from hprbUpdate.exe. A warning comes up that I must give permission to allow entry to my computer. Should I allow this or might it contain a virus?
    Sergeant:
    Champion:
  • 271 Answers
You shuold be having a HP software installed?...but it is better to ignore that update...it also can be some kin of virus
Posted on May 09, 2008
How do i disable administrator
Start\Control Panel\User Accounts\Change User Account Control Settings\Slide bar to bottom\click OK. Are you really sure you want to do this???
Nov 08, 2014 | Computers & Internet
Lexmark x1150 series lxbkpswx.exe
Are you having issues with lxbkpswx.exe for your model? If you have a firewall enabled on your computer, make sure to allow the lxbkpswx.exe in the program permission. You can also try to update the Lexmark X1150 printer software by visiting the Lexmark website at http://bit.ly/dPIEij. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen.
I hope this helps.
Nov 26, 2011 | Lexmark X1150 All-In-One InkJet Printer
My screen appear you are a victim of software counterfeiting how to erase this or resolve it thank u
Start Windows Registry editor and delete the folder "WGALOGON" located in the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows NT\CurrentVersion\WinlogonNotify. Delete all references in your registry to WgaTray.exe
Another alternative suggest that three files are installed Windows XP System Folder:
\WINDOWS\system32\WgaLogon.dll
\WINDOWS\system32\WgaTray.exe
\WINDOWS\system32\LegitCheckControl.dl...
The wgatray.exe process makes the check for genuine windows software. You can disable WGA by removing the execute bit on WgaLogon.dll. That way, winlogon can't call it as a notification package at boot, and since WgaLogon is responsible for running and maintaining WgaTray.exe, no more tray popups either.
To change the execute bit of WgaLogon.dll, first turn off Simple File Sharing. Now right click the file in Windows Explorer and open the Security Tab. Hit the Advanced button, uncheck the Inherit box at the bottom, hit the Copy button, then hit OK. Go through each listed user/group and remove the "Read & Execute" permission for that file, leaving the "Read" permission as-is.
Hit OK to apply the permission changes and close the file properties dialog. Restart the machine. You can now turn "Use simple file sharing" back on, if you want.
A third alternative posted on the internet suggest that users clear the content of file data.dat located in the following directory:
C:\Documents and Settings\All Users\Application Data\Windows Genuine Advantage\data
Save the data.dat empty file and change the attributes to "Read Only" - Restart you computer. Or start your PC in Safe Mode and delete the following files from Windows system32 folder - wgalogon.dll spmgs.dll wgatray.exe The WGA setup file is in C:\WINDOWS\SoftwareDistribution\ Download\6c4788c9549d437e76e1773a7639582...
If you don't use "Fast User Switching", you can disable the Windows XP Welcome Screen if you are logged in as an Administrator. This will remove the initial WGA Warning Screen:
1. Click on Start -> Control Panel ->User Accounts
2. Click on "Change the way users log on or off"
3. Uncheck "Use the Welcome Screen" - Choose Apply
4. Close the User Accounts window and the Control Panel
5. The next time you reboot your computer, the classic login prompt will be used
To enable Fast User Switching, you must also enable the Use the Welcome screen option. Also, Fast User Switching cannot be used when Offline Files are enabled.
Disable wgatray.exe - Some users are claiming that removing the WGATray.exe (or killing the WGATray.exe process) are working for them. Here's how to search for WGATray.exe file - Screenshot
None of these methods are guaranteed to work and people are just experimenting. Meanwhile Microsoft is not willing to relent to crackers this time and are planning to release an update of WGADiag2.exe utility in the next few days.
WGADiag2 will also fix the problem with registry key permissions may cause the installation of Windows Genuine Advantage Notifications KB905474 to fail from Windows Update:
Here's a manual fix provided by Microsoft. These permissions can be repaired using Registry Editor as follows:
1. Click Start, and then click Run
2. In the Open box, type regedit, and then click OK
3. Expand HKEY_CLASSES_ROOT
4. Locate the subkey HKEY_CLASSES_ROOT\LegitCheckControl.Legi...
5. Right-click the subkey and select Permissions....
6. Ensure that Administrators allowed Full Control permission
7. Repeat steps 3-6 for the subkey
HKEY_CLASSES_ROOT\LegitCheckControl.Le...
Microsoft has also published a kB article if the Windows Genuine Advantage (WGA) validation check process does not validate successfully on a Microsoft Windows XP-based computer, and you receive one or both of the following error messages:
Product Key Inaccessible 0x80080212
This problem occurs when you do not have the appropriate permissions for the Windows Genuine Advantage\Data folder. In the Permissions for Users section, make sure that Read & Execute, List Folder Contents and Read permissions are given. If the previous steps fail, start the computer in Safe Mode and rename the %allusersprofile%\Application Data\Windows Genuine Advantage directory.
May 20, 2011 | Computers & Internet
HI I HAVE A NC10 LAPTOP THE SOUND ICON IS THERE BUT I HAVE NO SOUND IT IS NOT MUTED.I HAVE VERY LITTLE KNOLEDGE ON COMPUTERS PLEASE CAN YOU HELP
The problem is that your laptop has no sound drivers. To fix, we need to install these "drivers" (a program that tells windows how to interact with your speakers correctly).
Assuming you're using windows 7, download the following file: http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&CttFileID=2477453&CDCttType=DR&ModelType=N&ModelName=NP-NC10&VPath=DR/200910/20091008134156078/Sound_Win7_6.0.1.5923.zip
Once it's downloaded, go to the place where you saved it, then right click and click "extract all" click next through all the steps and you should have a new folder. Double click on that and then double click on "SETUP.EXE". Click through all the steps, if anything asks for permission give it permission, if any warnings come up, accept them because you know this is a trusted piece of software from samsung, then finally restart your computer when you're prompted to.
Mar 13, 2011 | Samsung Computers & Internet
When I try to download anything I get a message that says my security settings are not allowing this download. I turned of security and still got the same message.
The computer is on alert, a messenger to the user. Several computer features perform alert functionalities. First, the firewalls are feature functions on the computer that prevents any program least recognized as belonging to the system from integration. Alternately said, a firewall on the computer disallows any program installations either achievable with CDs, Disk or DVD media or simple downloadable from networked structure of devices. In the situation that external programs were being introduced by the user, a message alert is displayed either as warning of possible infiltration or requesting permission for progress. Second, the computer security settings usually prevent any unauthorized integration of programs into users default settings. In which instance, the user has to disable the computers security else downloads of program installations would be nonexistent. Third, internet worked computer device usually has security setting for several purposes. First, internet security setting on the computer allows the default user of the computer to gain access to networked device often common with subscriber connections. Once an authorized user is recognized, permission is acquired to navigate the network. Alternately, internet computer securities disallow intrusion programs. For example while on the internet, it is possible to request programs either irrelevant in functionality, harmful ware clogging computers features as default. Finally, internet security make impossible hidden intrusions on the from several device operating under auspices least observable above program encryptions. However, a computer alert performs as reminder to the user that an introduction of programs from an elsewhere location is about to take place. Usually, a popup logo would require authorization approval to continue with accessibility or authorization disapproval for alternate response to be achieved. In the situation of yahoo messenger installation alert would require disabling the computer firewalls if any installation the program may be required. A computer firewall set as enabled would hardly allow installations or downloads unless the feature was set to disabled by the computer user for resuming of program transferability.
Jan 25, 2011 | Computers & Internet
My computer says that there may be virus if I download new yahoo
Jan 21, 2011 | Yahoo Mail
Whenever i try to download yahoo messenger it puts me a warning saying dat this file u r attempting to download may harm ur computer........y is it giving me dat warning?shudnt i download yahoomessenger?
Well my friend there is nothing to worry about. Actually the file you are trying to download is an .exe file which is why you are getting this warning. Actually in swindows mst virus comes in the form of exe(executable) file So this warning comes. No need to panic just download the messanger and install it. There will be no problem in that.
Regards, polysandy
May 20, 2010 | Yahoo Messenger
ACROBAT 9.1 WILL NOT INSTALL
“Error 1402: Could not open key [key name] .”
Your best bet here is to do a complete uninstall of all previous versions of reader before you try installation again.
  1. Choose Start > Control Panel (Windows XP), or Start > Settings > Control Panel (Windows 2000).
  2. Double-click Add Or Remove Programs.
  3. Select Adobe Acrobat [version] and click Remove.
  4. When prompted, confirm that you want to remove Reader.
  5. Repeat the above procedure for all installed versions of Reader.
  6. Restart the computer, and then reinstall Adobe Reader.
May 05, 2009 | Adobe Computers & Internet
Update does not complete
Ok so i was searching around the internet and found a similar problemwith another monitor so for giggles i tried there method. This is thewebsite where i found it : http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/d7c0e5bd-2fcf-48ff-a79b-c157014fc821/#page:3
The Second entry has a download.Download it then extract the files to the desktop. Dont worry if youget errors when the program runs it will fix them, if they come up justpress enter to keep going. Once the program completes install thedriver again and it should work as it did for me.
If you cant get to that website heres the post from it:
"Ok, once again i checked updates for HP My Display/Drivers, and found this:
http://www.portrait.com/dtune/hpw/enu/support_help.html
Here is a direct link to fix for "Access Denied" issue (HP LCD Monitors & Vista):
http://download.portrait.com/DRVFix.zip
Download DRVFix.zip. The fix contains 3 files including this readme. All must be in to the same folder.
  • readme.txt - This file
  • RestoreDisp.exe - Executable required to restore permissions. DO NOT RUN THIS FILE
  • DVRFIX.exe - Run this file in Administrator mode after reading the instructions completely
To perform the fix do the following:
  1. Extract all files in to a folder on your desktop
  2. Open the folder, right click on the DVRFIX.exe file and choose "Run As Administrator"
  3. Follow the on screen instructions. When complete, you should be able to install your drivers
If you find this helpful, please let me know.
I fixed this issue manually (from registry), about month ago.
Regards
Vesa"
There you Go, KD0BGA
Jan 16, 2009 | HP w1907 LCD Monitor
I have installed BT home hub broadband and since then Macromedia wll not open. Error message 'entry point not found macromedia.exe. It then says tries to open and gives an error message 'The procedure...
that sounds more like a permissions issue, with your settings on your isp/browser...
when changing ISP's it's sometimes necessary to 'train' that interface for your usual work places.
check your computers warranty here 4 FREE
Feb 29, 2008 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
417 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
