Question about HP PSC 2110 Color Printer
Keep getting right cartridge incorrect. what does this mean?
  • 1,218 Answers
For the check cartridge error:
Gently clean the contacts in the carriage, and on the cartridges with a paper towel or coffee filter moistened with water.
For the poor print quality or missing print:
Perform the Blot Test
Remove cartridge from machine, fold a paper towel back over a couple of times so it is about 4 layers thick, shake cartridge up and down hard, shake it over a sink unless you want to clean ink off the floor.
Now blot the nozzles of the cartridge on the paper towel, for a black cartridge you should see two black stripes, for a color cartridge you should see three colored stripes, if you don't have all stripes the cartridge is clogged or bad.
Have you checked the expiration date on the cartridges you are using?
Are you installing new HP cartridges, or refills?
You may be able to recover a clogged cartridge by swishing the tip in a saucer with a very small amount of warm water, then gently wiping it on a wet paper towel, be gentle the nozzles are delicate.
And do not trust the ink gauge on the PC, cartridges can dry up from the machine just sitting, the cartridges are vented, venting is necessary to let air in so that a vacuum won't develop in the cartridge. get more information and help for HP Printer Ink Cartridge .
Posted on Sep 07, 2010
SOURCE: right cartridge incorrect
alraedy tried that one but thnx
Posted on Oct 05, 2007
SOURCE: problem with lexmark X4580 cartridge error
me too. black #23?
Posted on Feb 18, 2008
Ajkill
  • 2035 Answers
SOURCE: lexmark x5470
A Right Cartridge Incorrect message generally indicates a communication error between the All-In-One and the cartridge. This can be caused by a faulty cartridge; however, it may be due to a simple interruption in the communication between the cartridge and the All-In-One.
The procedures below will help you to identify the cause of the error and resolve the issue.
Rebricking the All-In-One and Resetting the NVRAM
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action 1 Power off the All-In-One and remove the power brick from the back of the unit. Wait 20 seconds. Then reinsert the brick and power the unit back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Reset the NVRAM of the All-In-One
Yes: Continue to Checking the Cartridges.
Step Action 1 Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3 Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4.
4 Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts (click here for instructions). Continue to step 5.
5 Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6.
6 Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Posted on Mar 14, 2008
SOURCE: Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Posted on Jul 06, 2008
SOURCE: incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
Posted on Sep 05, 2008
What does 'Print Cartridge in right stall not supported' mean?
It means you have a faulty or incorrect cartridge installed on the right side position. It could also mean the contacts are dirty or misaligned. Remove the cartridge, clean with rubbing alcohol and reinstall.
This is not a unknown error particularly if you are using cartridges other than the HP brand. Other people will tell you it is fine to use off brand cartridges or refilled cartridges. For myself, I have never had luck doing that - on the other hand, I have never been disappointed using the more expensive cartridges recommended by the manufacturer across several brands including Epson, Canon, Compaq and HP.
Try cleaning the contacts and ink jets. You may have to replace the cartridge. If that is the case, I would return the faulty cartridge and get a store credit.
Just a few thoughts for you to consider. Thank you for using FixYa.com today.
Mar 03, 2011 | HP PSC 2355 All-In-One InkJet Printer
Changed cartridge in printer few weeks back - took several attempts to get cartridges to align afterwards. Now say to remove and check cartridge (appears to be problem with colour cartridge!). When put...
It might mean that your cartridge has become demagnetized. That happened to me and I had to replace the cartridge. The little brass covering at the front of the cartridge is very delicate and can become demagnetized if handled incorrectly. You can buy refurbished ones on line and they are not as expensive, but that is entirely up to you. Good luck.
Jan 05, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Replaced ink cartridges and keep getting "incorrect Cartridge" displayed. Using refills that have been fine before.
Welcome to Fixya
Dear User
Remove the cartridge and try to clean the contacts and reinsert if still shows the same message .you have to replace that particular right side cartridge.
Hope you got it..Thanks for Connecting FIxYa..
Aug 20, 2010 | Lexmark X4550 InkJet Printer
I just bought two new cartridges for my Lexmark X3550 and I keep getting an error message that the right cartridge is incorrect
HI,
I was getting that message too, for both cartridges, I did a search on the internet and found that its a manufacture problem and it has a little upgrade program you can run to fix this problem, and viola, it started working, so happy now!
http://lexmarkanswers.blogspot.com/2009/06/leftright-cartidge-incorrect-huh.html
Aug 15, 2009 | Lexmark X3550 All-In-One Printer
New cartridges do not work in Lexmark 3550 Printer
Are you sure that they are installed correctly, seated, etc.? Do you have the right cartridges? Have you aligned them?
Jul 05, 2009 | Lexmark X3550 All-In-One Printer
Cartridge errors..cartridge incorrect
sounds like they're the type of cartridges that cannot be refilled, due to the computer chip on them.
Dec 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Installed new cartridges; keep getting error message
I'd say your using dodgy aftermarket or non HP cartridges, you could put your old ones in and see if message goes away, if having problem when using with Original HP cartridges post back and I'll did deeper for you.
I dont work for HP, I do know printers :-)
Dec 28, 2007 | HP Deskjet 5440 InkJet Photo Printer
Try cleaning the contacts on both the cartride and in the cartridge bay
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
HP PSC 2110 Color Printer Logo
271 people viewed this question
Seeker5211
Seeker5211
