Question about Apple MacBook Mac Notebook
My sound isn't working. the headphone plug has a red light coming from it.
  • Apple Expert
  • 481 Answers
The audio out jack on current MacBooks is a dual-phase component that works with both electronic and optical equipment. When you insert a plug into the jack, the red light will come on as the machine attempts to make an optical connection. If the red light remains on when there is no object inserted, it is an indication that the sensor that detects objects is malfunctioning. If your machine is under warranty, you will want to bring it in to an Apple technician for repair. If not, some users have had luck cutting off the top of a cotton swab and using the shaft to probe gently down deep in that hole and jiggle the sensor back into position. It goes without saying that you assume responsibility for any damage you may do to your machine during this procedure.
Posted on Nov 01, 2010
No sound tcl 40F S3800
when headphones are plugged in a conection is broken to stop sound coming from speakers try plugging in and out jack plug for headphones a few times
Jan 02, 2017 | Televison & Video
No Speaker Sound, Thinks Headphones are Plugged in
If you don't plan on using the headphones - take the cover off and there may be a cable to the headphone jack board that can be unplugged. This will disable the headphone jack from sending a bad signal to the micro. If you want to be able to use the headphone, then the jack is going to have to be replaced.
Jun 16, 2013 | Pioneer VSX1020K Receiver
On my macbook air, the volume isn't working
Check the headphone jack on the side of your laptop. If you can see a red light inside the jack, then the sensor that determines when headphones are plugged in is dirty or jammed. Compressed air and/or removing and inserting a headphone cable repeatedly can sometimes fix it for a while.
Aug 07, 2017 | Apple MacBook Air
Problem with sound
Headphone socket is pushed in too far, need to hook the end of the socket inward to contact the speakers when headphone is not used.
May 02, 2012 | Computers & Internet
My macbook air does not play any sound anylonger, it suddenly stop working and a circle with a line inside appears when I try to increase or decrese the volume...?
You laptop may have sound prefs set to external speakers, or if there is a red light coming from the headphone jack. the mac thinks the headphones are still there.
Plug in and unplug the headphones an see if the red light goes out. may take a couple of times. Be gentle
Aug 17, 2010 | Apple MacBook Air
Sound Issues
Your headphone jack is either contaminated or broken. Clean any debris you see inside, if that doesn't help, it may need replacement. If you want somebody else to do it for you go to Macbook Repair. If you want to do it yourself, here is an Macbook Repair Guide that shows how to repair a Macbook.
Jun 18, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Bose Headphones only works on left side.
Have same problem. Play with the plug in the socket. I'll bet it you can occasionally get both working. Not a solution since it probably won't stay working. I have an old plug and it fails too. I'm afraid they did't make their plugs to the right tolerances. Used to work once. Annoying for this expensive a headphone.
Mar 29, 2009 | Audio Players & Recorders
Headphones has red light
Hello, I believe I just figured out the solution to this problem. I was experiencing the same thing, and as I was just showing my friend the problem I noticed that the green light came on after I turned on the music on my computer.
So, after removing the headphones from the base, the green light will come on only if there is sound playing from the computer (It takes a few seconds to turn on). It seems like they should have mentioned this somewhere in the manual...
Dec 04, 2007 | Sony MDR-RF970RK Headphones
Apple MacBook Mac Notebook Logo
48 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
