Question about Sharp LC60E88UN 60 in. LCD TV
Sharp lc-60e88un is less than a month old. It shuts off and on all by itself randomly. No blinking light or codes.... HELP!
  • Sharp Master
  • 8,457 Answers
Call 1-800- USA Sharp for warrrenty repair.You have to talk and test by the Sharp Tech. "Randomly"known as intermitten problems,hard to determine what exact parts are dying.
Posted on Sep 01, 2010
Picture freezes. Shut it off and turn it back on and the picture is fine for about 15 seconds and then it freezes up again.
Try to boot into safe mode and then see whether you're getting the same problem or not. Try before it freezes.
Sep 30, 2015 | Sharp 60IN LC-60E88UN AQUOS LCD HDTV 240HZ...
Sharp won't turn on blinking power light
All this indicates is that the control system has detected either a catastrophic fault, or what it thinks is a catastrophic fault, on the main board. Is the light flashing with a repeating pattern of on and off? If so, that can be used to diagnose where the trouble may be. If it's just constant flashing, then there no option but to service the set on the workbench, althogh the most probable cause will be faulty electrolytic capacitors in the power supply.
Nov 11, 2013 | Sharp 60IN LC-60E88UN AQUOS LCD HDTV 240HZ...
I would like to ask that my 7 years-old SHARP LC-37A33M is having some issue which the problem is, when i turn it on either by remote or manually, it came on and picture came out, but after 3 blinks, it...
It sounds like the back-light inverter board should be checked. This type of whistling sound will come from it, if the transformer on it is faulty. Three blinks of standby light too denotes it. If you wish to get more details about the faults and blinking codes to sharp TVs, check this link. http://electronicshelponline.blogspot.com/ There are blinking codes to many brand TVs including Sharp models. Pull up older posts there by its left side bar.
May 26, 2013 | Televison & Video
Sharp lc 60e88un shutdown the 24v from power board no 12v
to check for led eror vol_ channel+ hold and press power switch once andrelease only power switch triangle light should come on then release the vol and channel knobs if set comes on the leds defective in screen
Mar 02, 2012 | Sharp LC Televison & Video
Ok.... I got a new power supply board and the tv is still doing the same thing. (Sharp Aquos 37in LC-40C37U) So if it is not the power board then what could be wrong with it. I'm getting no power and only...
The pattern of the blinking is a code. If the power light is blinking by itself once per second or thereabouts it could be loose connection to Inverters, reload firmware, Inverter Unit or LCD Panel.
May 06, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
The TV will shut off by itself randomly (anywhere
Sounds like the TV is going into the "protect mode", usually means there is a failure present and it's shutting down to ward off any serious damage to the electronics. The status light will usually blink a error code along with this symptom, call a service center and let them know how many times the light is blinking in a continious pattern and that will help them to diagnos your TV problem. Good luck and Merry Christmas!
Dec 25, 2009 | RCA D52W135D 52 in. TV/DVD Combo
Sharp LC-37SH12U LCD TV is 20 months old and would not power on
Your power supply unit needs servicing on some part replacements. bad capacitors, voltage regulators, hi-watt resistors,....etc
Nov 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LC60E88UN 60 in. LCD TV Logo
379 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
