I took my Denon receiver to a local repair facility, because it wouldn't fully "boot", after shutting down, when I tried to run a computer rca plug (on both ends) from our computer to a in wall - monster cable jack. I.e. Guitar center sold me a cable with a double ended RCA computer plug so I could run music from our computer program, into our AVR3801 Dennon receiver. Music played on one of the two channels for about fifteen minutes, and then the receiver shut down to try and protect itself; but when I tried to reboot the receiver (after pulling out the cable jack, it couldn't complet the full bootup process. Eventually, the computer started malfunctioning, too, about eight weeks later!! The technician at the reapir facility noted that the micro control and switching circuits were damage, and HE SAID HE CAN'T GET THE PARTS FROM DENON. Do you know of anyone that I can contact that still has Denon parts (i.e. the nicro control...for my particular model type? We bought the unit back around 2002. Thanks for any help that you can provide...
  • 4,234 Answers
Please post the exact symptoms. What do you mean by not "booting up"? Does it click on then click off? This would mean that the unit is in protect mode which is usually caused by a problem with the output amplifier section not the Micro. Do you have any experience with electronics repairs? If so, I can try to guide you through the repair.
Let me know.
Dan
Posted on May 09, 2008
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
Heard a "pop" and my
Maybe. Clearly something blew up. Diagnostic time costs money. Then there are parts and labor.
You can get a new one on ebay ending tomorrow for as little as $140 delivered.
http://cgi.ebay.com/Denon-AVR-2105-stereo-receiver-/220774248046?pt=Receivers_Tuners&hash=item33672bae6e
Apr 25, 2011 | Denon AVR-2105 Receiver
Denon AVR 2105 power shuts off, tried resetting the micro processor and no luck. Please help...
The receiver has an internal problem like bad power supply or burnt channel. You need to bring it to a local repair shop or mail it here.
Feb 06, 2011 | Denon AVR-2105 Receiver
Avr 688 shuts down immediately after powering on
Internal problem with power supply or one of the channels. Bring it to a repair facility.
Aug 09, 2009 | Denon AVR-685 6.1 Channels Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
I have got a nuvi 260 and it wont come on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 260W shuts off before it fully loads maps
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
My denon avr-a10se stop working. When I start, aftr thr quick intiation the amp shuts itself and the red power light start to blinvk quickly - please help
This unit is in protect mode. This means that a problem was detected in the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common failure parts are the output transistors. These usually run between $5-$15 each. Add in the local labor rate for the total repair cost.
Dan
May 20, 2008 | Denon Audio Players & Recorders
Denon 1601 avr
The unit is in protect mode. It has detected a problem in the final output stage and has shut down to prevent further damage. Disconnect the speakers completely and try turning it on. If you still get the same symptom, the problem is inside the unit and repair is required. Usually when this occurs, the output transistors have failed. There will be at least 2 that need to be replaced. Figure on parts costing around $15-$25. Add in the local labor rate for the complete repair cost.
Dan
Apr 07, 2008 | Denon AVR-1601 Receiver
114 people viewed this question
 Grubhead
Grubhead
