Question about Casio MTP3036A-2AV Wrist Watch
How to change battery - Casio MTP3036A-2AV Wrist Watch
  • 831 Answers
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Posted on Sep 01, 2010
    How do you change battery
    How to Change a Watch Battery with Normal Tools - YouTube
    ? 9:18
    https://www.youtube.com/watch?v=gFmV7NIjVsw
    Sep 1, 2011 - Uploaded by RichsMethods
    Hello, here's a video that provides straightforward, easy to follow steps on how to change a watch battery. I ...
    Replace Your Watch Battery Yourself With Household Tools ...
    ? 7:32
    https://www.youtube.com/watch?v=L4Y7pDonkmk
    Aug 15, 2013 - Uploaded by tsbrownie
    How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...
    How to Change a Watch Battery: 13 Steps (with Pictures ...
    Dec 15, 2015 | Watches
    How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
    Timex Triathlon Ironman Watch Battery Change - YouTube
    ? 2:44
    https://www.youtube.com/watch?v=x_C7VsE8Kks
    Jun 26, 2015 - Uploaded by Lin Le
    Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
    How To Change CR2016 Battery In Indiligo Timex Watch
    www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
    Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
    Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
    Can you change the battery in the chest strap for polar f6
    There are two types of straps for Polar:
    1) hard rubber/ solid - These can not have the battery changed.
    2) soft strap with connector in middle - these you can change the battery.
    If you have the soft strap, it will have a small hard around 3 inch long block that "snaps" onto the strap to connect it. These have a battery compartment. Turn it around and you will see the outline for the battery compartment. These are not always easy to open, and the batteries are a little harder to find. Take it into any watch repair and they should be able to pop a new battery in for you pretty easy.
    There is a link on my tips and tricks page to get manuals for Polar products, the T-31 wearlink is the product we are talking about, it has the how to change the battery and battery type.
    Jan 12, 2011 | Polar F6 Wrist Watch
    I changed the battery in my Fossil ladies watch and it still will not keep time. The hands are going around but it is not keeeping up with the time
    mcdevito75 here, Just had the battery changed, if the watch was running fine before the last battery died, and now with this battery change the watch can"t keep time, try another battery as any Battery can be weak just from storage.
    Jun 14, 2010 | Fossil JR8096 Wrist Watch
    How to change the battery
    the metal cover will be sliding and if you will slide it left or right battery should come out.
    Thanks
    Nov 25, 2009 | Kenneth Cole KC2315 watch
    Battery change and then reset
    If you open already the watch,and you want to take the old battery,there is a clip that's lock the battery twist that lock.then the battery comes out and replaced with a new one. If you have already put the battery and no display you must reset it by shorting battery connection,in the plate there is arrow guide to the hole where you put your tweezers to short the connection.then the display appears 8888,that is already resetted take the tweezers..
    click below for video guide;
    G-ShockBattery Change Tutorial
    hope this may help
    DON'T FORGET TO RATE
    Regards,
    VOTIT
    Jul 29, 2008 | Adidas Watches
    Softwatch by Exaequo
    call 973 444 7400 solve all watch &parts problems
    Mar 20, 2008 | Watches
    Casio MTP3036A-2AV Wrist Watch Logo
    1,284 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
