Question about Viking Professional VGRT362-4G 36 in. Gas Cooktop
The filter light on my updraft 4 burner gas cooktop is on - is that something I can fix myself and if so, how? Thanks. Kathy
  • 33 Answers
It should mean the air flow is low. you need to change the filter that is what it is trying to tel you. you should be able to do it yourself
Posted on Sep 01, 2010
Need new electric cooktop to work with downdraft CV2236N-01.
never heard of one needing downdraft usually updraft . gas maybe but not electric
Apr 12, 2014 | Maytag MGC5430 Gas Cooktop
The igniter doesn't work at all. If I turn any knob to the ignite setting, you can hear the gas coming out but there is no ticking sound, and therefore no ignition. Can I fix this myself?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 03, 2010 | GE 36 in. JGP628 Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
I cleaned the gas top and the two left side burners do not ignite
Take the burners out, then take a needle and stick in the small hole where the gas comes thru.
Jul 15, 2009 | Maytag MGC5430BDS Gas Cooktop
One burner igniter fails to spark after getting wet
Each burner has its own switch to direct current to the igniter. It appears that one of the four switches burned or shorted out, while the other three survived the flood. These switches are replaceable, so that's how I'll fix the problem.
Jun 26, 2009 | KitchenAid Cooktops
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Exhaust turns on automatically in burner mode
Hello
I have the one with the 4 burners and the grill, and when the grill in on the fan has to come on, and it does automaticly, but once you finish with the grill you have to change it back to stove mode by putting the 2 burners back or the fan will allways go on when you turn the switch. It is a safety regulation for the fan to be on with the grill to avoid the fumes......I know I hate that too.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 19, 2008 | GE 30 in. Profile JGP979 Gas Cooktop
Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
May 27, 2008 | Dacor Preference SGM304 Gas Cooktop
Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
Apr 17, 2008 | Cooktops
Viking Professional VGRT362-4G 36 in. Gas Cooktop Logo
70 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
