Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Flashes F1 and a wrench symbol... water doesn't drain
  • Fisher and P... Master
  • 3,247 Answers
Assuming you are getting the F1 error in both drawers.
This means there is water at the base of the housing under the bottom drawer.
Turn power off and take the drawer out. You will have to pull out the plastic pins on either side and get the front cover off. This will enable you to pull the drawer out from the slide bar for better access. Use towels and hair dryer to get rid of all the water. The flood switch is mounted on the power board. Use hair dryer to dry this out.
Put everthing back and turn power on.
Post a comment if this is not fixed or the F1 is only coming in one of the drawers.
Please rate this solution.
Posted on Sep 26, 2010
SOURCE:
After one min. flashes 'f1 wrench' and tuns off
Water is collecting at the base of dishwasher housing (under the bottom drawer). Need to dry it up and find out why. Make sure the dishwasher is disconnected from mains supply when you work in it.
Jan 03, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Wrench symbol flashing
It might be helpful if you can recall the code that was on the panel when the wrech symbol was flashing. something like F1 or U2
Feb 04, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Cannnot turn off or move to any wash leve. Keep getting F1 signal and a wrench symbol.
The F1 code indicates an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose.
The F1 fault could be from your lid actuators not working properly or the lid seal needs to be replaced or check ur flood sensor it located at the back under a black plastic cover, the sensor is the little add on at the left. make sure u turn off power before touching anything
Hope helps.
Jul 13, 2011 | Fisher and Paykel Dishwashers
Won't shut off says F1 with a wrench symbol
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 21, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishwasher showing wrench symbol after using dishwashing liquid
I am assuming this F1 error is coming in only one drawer and that you are able to run the second drawer as normal.
In the case of your dishwasher the F1 error occured because the foam would have overflowed over the drawer top into the base of the unit. This would have triggered a flood switch which is there to protect water damage to the dishwasher. You can either wait a few more days until the base of the dishwasher drawer unit dries up or you can dry it yourself.
To dry the base, extend the drawer as far out as possible (turn mains power off first). The use a few towels and push them on to the base. Pull the towels out and dry the base especially the centre of it with a hair dryer.
The F1 should disappear once you put power back on .
Hope this helps. You have a very helful child who sets the dishwasher up. I have to keep pushing my children to even empty it.
Jun 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Same problem
Below is the service manual. Use the FU (fill water) function in the diagnostics and then use P2 to drain the water. Open the drawer and watch will testing.
Good Luck
http://www.scribd.com/doc/6462163/DD601V2-Manual
Jul 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 light flashing with a picture of a wrench
See http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm, or http://www.fixya.com/support/t103415-fisher_paykel_dd_603_dish_drawer
Aug 24, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
206 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Mark Davis
Level 1 Expert
Bruce Denton
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
