Question about Black & Decker 14.4 Volt Battery Charger #5101181 02
Black and decker smart charger f03 code - Black & Decker 14.4 Volt Battery Charger #5101181 02
3 Suggested Answers
  • 384 Answers
SOURCE: black and decker cd12c cordless drill Charger
I would guess 12 volts
Posted on Jun 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: Black & Decker LITHIUM CHARGER 14.4v to 18v . 90539541. fits A1518L, HP1884L
could be either one. Have you tried another battery? If not I would recommend taking BOTH in for inspection. They have a scanner that can detect if the battery has a problem. If you need to find a service center close to you go to dewaltservicenet.com and they have a locator. Let me know if you need more assistance.
Posted on Feb 10, 2012
My 98 blazer acts like the battery is dead but when i hooked it to a battery charger it said it was full and running at 9.1 when it should be running at around 12 then said error f03. so what does that...
It means the battery charger is your problem. Find an old-style simple battery charger, not one of these new "smart" chargers. The simple ones allowed YOU to decide whether to charge or not. Placed more responsibility on you, but a simple charger would WORK for your battery.
At 9.1V, your battery's DEAD.
Jul 12, 2014 | Vector Black And Decker High Frequency...
Vec 1097 A battery charger always give cod F03 with any battery
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Dec 06, 2012 | JUMP START SYSTEM
What does the code F02 mean for a smart battery charger
It means one of two things. Either you do not have a good connection from the charger to the battery, check and clean the clamps and terminals, or the battery has too low a charge. A smart charger needs to measure the existing charge before it will work.
Aug 24, 2012 | Black & Decker Tools & Hardware - Others
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
I have a Vector Smart Battery Charger 2/6/12 model VEC1088A-M. I am trying to charge a trolling motor battery but I get an error messager "F03." What does this mean?
F03 means 1 of 2 things:
INTERNAL OPEN CELL - Bad battery. Battery needs to be replaced or
SULFATED CONDITION - Battery needs to be reconditioned for 24 to 48 hours. See owner's manual.
May 27, 2011 | Computers & Internet
What does "sulfated Condition" mean
The battery is dry. It has insufficent acid in the battery
Feb 26, 2011 | Vector Black And Decker High Frequency...
What does F01 code mean on a vector vec1097A smart charger
F01- Internal Shorted Cell Battery-(Cannot Be Charged) or
Excessive Load On Battery While Charging (Check Load)
*If this shows it is recommended to take your battery to a certified auto center for evaluation.
This Info Came Directly From The Manual.
May 02, 2010 | Vector Black And Decker High Frequency...
What does F03 mean
F03 is an error code with two possible meanings.
1) battery plates are sulfated, meaning they have a buildup of lead sulfate on the battery plates. Try charging the battery using the "Recondition" button on your charger. If this does not correct the problem then it may be option 2:
2) Open cell in battery. Have battery tested at an auto parts store and be ready to buy a new battery. An open cell means the battery is no longer usable.
Nov 18, 2009 | Vector Black And Decker High Frequency...
Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Sep 21, 2008 | Electronics - Others
Black & Decker 14.4 Volt Battery Charger #5101181 02 Logo
998 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
