Question about Danby Heating & Cooling
The light for the overfill drawer is flashing but there is nothing in it. Usually if this happens, I open it and close i and it goes off but it won't work this time. I've unplugged it and tried many times but the red light is flashing. The main container is only 1/4 full. It is only about 5 years old and usually only gets used for two weeks in the summer. It is a Danby Noreen
    President:
  • 3,074 Answers
There is a sensor/switch and it is stuck or gone bad. hope this helps tim
Posted on Sep 01, 2010
Dishdrawer: Does not start, just beeps once
Some sensors on the unit are telling the controller there is a fault.
Most likely the sensor checking the drawer is open or close is giving a fault. It is likely the drawer has come off the rail.
May 22, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
A Neff warming drawer red light flashes
There is a 'plug and socket' connector at the back of the warming drawer which does wear and eventually start to make erratic or no electrical contact. The drawer electronics read this as an open drawer and switch off the power to the heating element (flashing red light). If your competent the drawer can be stripped down and the contacts serviced or replaced otherwise consult a service technician.
Dec 07, 2012 | Neff Ovens
POT AND PAN DRAWER WON'T CLOSE PROPERLY
Take out the drawer. Lift it out. Make sure nothing is in the tracks. Take everything out of the drawer. Put it back and watch the tracks. If it closes properly you've over loaded it, otherwise you have bad tracks.
Jan 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Have a AML 125 front loader which is flashing three lights at us: The lock light flashing very fast plus Rapid and 1200-600 lights flashing. When we power up and close the door it starts doing this and...
Top 10 frontload washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nessisary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 13, 2010 | Ariston Technologies Washing Machines
CASIO TE2200 Error E010 while drawer is closed
This type of problem is normally caused by a switch. When the drawer opens, the switch closes and the machine goes into 'drawer open' mode to prevent another transaction. The switch or the switch activator has probably failed.
Remove the entire drawer assembly, meaning everything that comes out when the drawer is opened. Use a flashlight and look at the inside rear of the drawer opening to see if you can see the switch. It may be a lever or a button and it may be in line withe the drawer or in may be off to one side. When it is located, try to press on the button or lever. If you can and the machine goes back to 'normal mode' the problem will be identified and you will know that the switch is good. Now you need to locate what actuates the switch to see why it is not making contact. Look on the part of the drawer that should come in contact with the switch. If a small, thin piece of plastic has broken off, tape a small piece of a hard substance in that area. Close the drawer to see if the 'open' message goes away. If id does not, try a thicker piece. Repeat until the 'open' message goes away. When that happens, glue the last piece in place.
If the 'open' message does not go away when the button or lever is press, it indicates that the switch is bad and needs to be replaced. Most of these switches make contact when the button or lever are not pressed. In the short term you could locate the switch and disconnect one wire. That would simulate the button being pressed. You would just need to remember to not start another transaction until the drawer is closed.
Good luck, and please let me know how it works out.
Feb 22, 2009 | Casio Parts Cash Register PC Desktop
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Alarm on continuously!
please try to reinstall the printer drivers
Feb 13, 2009 | Citizen IDP3541 Matrix Printer
The top drawer intermitantly makes the drawer opening noise
On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. Wipe these areas with a clean dry cloth.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Heating & Cooling Logo
82 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
